Chance to buy 100$ flat head.
I would not pass on the chance to buy a flatty for $100.00 . Chances are 1/2 of them are cracked somewhere . You could always recoup some of your investment on selling spare salvageable parts or scraping out the dead cracked blocks and such . That is what I did . Took 3 engines to get a good block and sold off some spare parts . Good luck .
Here's my take, like we want to hear it again.... Mtflat is a very knowledgeable flathead expert, as he is one of the moderators on the flathead v8 website. When I read his post, I understood, because I knew him, that what he was referring to was that with his vast knowledge, and every little difference known by him, would fill a book, and not just one post. So what he did was he generalized the engine families based on year groupings. Now, moving on... cracks in flatheads are very common, but not the end of the world. Sleeves, or welding, are two simple repairs done by a competent machine shop. Lastly, I would get it for $100 anyway, just to have a spare carb and other little parts, heck maybe even another flywheel for redrilling for a modern T5 if desired.
Oh yeah, and the right side on top by the intake is a code for determining the year. Find those, post them here.
Thank you for telling me were too look on a flat head to find the code i looked at all the links on the site that were posted on this forum and found usful info but the guy i was dealing with did not completely understand what i was talking about because they are not his engines. now i can explain it better to him. thank you that is what i was after. i only bought the engines with out looking at them because they turn over, and they are 230 miles away. i will be picking them up next week friday.
thanx for all yourhelp and sory about the misunderstanding of words on my part.
mitch
mitch
here are the numbers off that engine. 59A-B- 59A-60508 G23711 and 59 on the top of the bell housing. BUT the bell housing is cast into the block so i think that means it is out of a 48 car not a 48 truck??? there are 4 more engines out there and i will give the nuber to anyone that wants it because the guy wants to get rid of them. let me know.
Funny, but I didn't find this thread after my first post. I'm not on here every day. Sorry if I gave you the wrong impression Mitch, I just didn't know where to start that day. Josh gave you a link to the best website for visual comparisons of flathead engines.
The numbers you have are the part numbers for the heads 6050/6049 You're right about the car vs truck engine IF the engine is a 48 - but the same numbers were used from '45-'47 trucks and '45-'48 cars.
No offense taken and no apology needed. The guys are too kind - sometimes I am a dumb *** without even trying....
It might help if you mentioned to the guys the general area where the engines are located. Good luck with your project!
Tim
Tim
hey this is mitch and i do feel like i owe you an apoligy mtflat. i think i may have been having the same kind of day that you were. the engines are located in North Branch MN. just north of the cities. would this engine mount up to the same transmition? i dnot think that the craack can be fixxed but i should know by tomarrow. the engine i bought i think is a good engine.
thanx for all help and information
mitch
mitch
If they were 230 miles in my direction I'd be interested. Should be some guys in the MN/WI/ND area that could use one. In fact you might share that info on the website I've included at the bottom of this post.
The partial bellhousing on the 59 is the same as the bolt-on half bell the 8BA/8RT's. Transmissions are the same and should bolt right up. I'm looking at putting a 59 in my 48 2 ton when I get it running - that or a 12v cummins turbo
I've got a few cracked and otherwise busted flatheads under my workbench. They're great for educational purposes. Every time I take one apart I learn something new. There are literally hundreds of variations - most don't mean much, but some are critical depending on the intended use.
If you really want to learn flatheads, here's the best site on the web. You have to register to post there but it's well worth it. Be sure to check out their techno page - it's crammed with archival info. http://flatheadv8.org/phpBB/index.ph...3bb6aa6bf5d399
Mitch, I must admit that I was a little disappointed to see your initial angry response to MTFLAT's reply on your thread, but now I REALLY APPRECIATE how you have come back to engage in a reasonable and respectful dialog. My disappointment was that I could see the FTE forum breaking down into a worthless brawl of insulting exchanges. I have not been on the FTE very long, but I HAVE been on other boards that did go the way of insulting exchanges. Your measured and respectful response has earned my respect and I believe that you and many others who participate in the forum are collectively a valuable asset to the antique car / truck hobby.
#28
Well tanks to everyone and i will definetly let you guys know how my original block turns out. i was told that the crack may not be able to be fixed so i brought it to the guy i know that does alot of crack repair and ALOT of flat head work. but if it cant be fixxed then i guess my mom just got a sweet new flower pot. haha
thanx
mitch
thanx
mitch
#29
In don't want to hijack this thread but I have a 1951 F-1 with the original flathead and three speed transmission.
The truck sat for years and appears to be in original condition - won't turn over so it is locked up.
I would like to make this engine and trans available to anyone who needs one. I am in Northern CA.
I also have the differential and front axel that I am not going to use.
If you need one of these let me know.
This is not a classified add - just want all to know that I have these items that I am not going to use.
I plan on putting a Ford IFS, a 4-link rear suspension, a 460 engine, and c-6 in my truck.
So, as you can see the parts I have available are just sitting and in my way.
Let me know if you are interested.
thanks
Dan
thanks
Dan
79f-250custom
45
03-23-2008 12:23 PM
Customcab
16
02-24-2008 08:11 PM
