1991 F150 Problems---Won't Stay Running!!
Hello, I have a 91 F150 4 wheel drive that I am having some issues with. The truck does not want to idle and I have to rev it up at a very high RPM to get it to move. Once the RPM's are up, it will run but not very good. I was getting around 4 MPG and it is getting worse. It spits and sputters at low RPM and dies. I have not run any type of code scanner on it as all I have is an OBD II style at the moment.
My guess was fuel delivery problem, possibly the regulator. Could someone give me some direction as to where I should start?
Any help appreciated.
First off welcome to the site.
You need to pull the codes but you do not need a scanner but it does help.
If you do not know how go to this url:
Ford Fuel Injection How To Run a Self-Test
PapaBearYuma
16
11-13-2016 08:18 PM
wordmaster
03-12-2010 08:53 AM
131will
20
01-12-2008 06:55 PM
