Exhaust to be smog legal in california?
Old 01-19-2010, 09:23 PM
Six5
Six5 is offline
Six5 is starting off with a positive reputation.
I want longtube headers but what do I need to do to make sure they will pass smog in California? What a bout a good option for a catalytic converter?
Old 01-19-2010, 09:53 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Find a friendly smog referee and contribute to his retirement fund.
That's probably cheaper, just select one of the many CARB certified universal replacements available.
Old 01-20-2010, 12:17 AM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
it depends on what year car it is. your allowed worse emissions for later year car and trucks. headers are really hard, if its a newer car, then it needs to have bungs for o2 sensor. if its older its gotta have bungs tapped on the top of each cylinder for the smog pump. and you can get a high flow cat, BUT they tend to only be good for 2 or 3 years before you are gonna fail your test. best thing to do is to have your smog test done, install whatever you want. keep your factory stuff! when your smog comes up again just bolt your factory stuff on. your only lookin at about 6 hours work every 2 years.
Old 01-20-2010, 12:21 AM
pnp522
pnp522 is offline
pnp522 is starting off with a positive reputation.
only shorties legal here and only a few replacement cats available now. Depending on the mileage of your truck you might not be able to replace it unless it fails smog. Ain't CARB grand according to AB 32 they are going to outlaw all diesel engines on-road and off-road older than 5 years including industrial and construction equipment.
Old 01-20-2010, 12:25 AM
85e150
85e150 is online now
85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation
Anything you put on has to be OEM or CARB approved. Header manufacturers will have the CARB number available. Doug Thorley would be an example of someone selling CARB approved headers.
Cats have to be oem or certified. Lots of fraud with stolen cats etc, so now you can't install used--pita.
Old 01-20-2010, 05:21 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I can't believe they are going to outlaw all diesels that are older than 5 years old. That makes no sense to me.
Old 01-20-2010, 10:55 AM
oreocreaming
where did you hear they are going to outlaw them? everything i have read is that anything 5 years old and newer have to have emissions testing. nothing about older being outlawed. the only people that cant have a restriction on what they can have are companies with a total fleet over 50. and the 5 year limit is on equipment. backhoes, forklifts, loaders, scrapers ect.
Old 01-20-2010, 10:57 AM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
I call BS on this. Link?
Longtube headers are illegal for street-driven vehicles in all 50 states.
Old 01-21-2010, 01:30 AM
TexasGuy001
Why would they have a 5 year limit on loaders and backhoes etc? Companies can't afford to replace them that often.
Old 01-21-2010, 12:00 PM
oreocreaming
because the epa are jerks. most construction companies are going under in california for that exact reason. they say it has to be under 5 years because the diesel emissions are much lower in the newer engines.
Old 01-21-2010, 01:44 PM
85e150
The ports of Long Beach and Los Angeles are banning the older trucks, but not statewide. The port story is a long one, involves labor issues, politics, etc, and is enough to p-off the pope.
ALL emissions laws and info is available and public. Sites like this here:
Diesel Vehicle Smog Check Inspections Information
So, if you hear some blanket statement, or if you have questions about what you can/can't do, go to the official source.
Old 01-22-2010, 12:26 AM
Duramaxfanatic1's Avatar
Duramaxfanatic1
Duramaxfanatic1 is offline
Duramaxfanatic1 is starting off with a positive reputation.
your best bet is to keep everything you improve the engine with and put it all back to stock unless you know a guy
diego-ted
16
11-02-2013 01:48 AM
gdunn
30
02-23-2013 10:48 AM
WJones72002
13
12-02-2012 01:00 AM
andym
03-14-2011 04:10 AM
duhlry
Aerostar
15
03-25-2005 07:32 PM
Quick Reply: Exhaust to be smog legal in california?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
