B1450 code
Old Jan 19, 2010 | 02:27 PM
mndiesel's Avatar
mndiesel
B1450 code
B1450- Wiper Wash/Delay Switch Circuit Failure
The wipers and delay work fine but the washer doesn't. Has anyone seen this code before and is there a way to check the switch or the pump motor to know which one it is. I thought the washer fluid was frozen till I got this code
Old Jan 19, 2010 | 05:02 PM
mndiesel's Avatar
mndiesel
No one has ever seen this huh,oh and by the way the Fuse is good
Old Jan 19, 2010 | 05:04 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I get it every once in a while when I pull codes. I haven't figured out why or if it actually pertains to anything.
Old Jan 19, 2010 | 05:35 PM
tdpower's Avatar
tdpower
I was getting an intermittent washer failure and turned out to be the multi-function switch. I took it apart and cleaned it with electric cleaner. PITA to put back together. You should be able to find one new for about 75 bucks. Check at the pump for power when you press the washer first. Could be the pump. I don't have AE so don't know if that is the code.
1972-34ton
Electrical Systems/Wiring
15
Dec 29, 2018 09:30 AM
Rasalas
Oct 6, 2016 07:45 PM
trippn4re
23
Jun 2, 2014 04:16 PM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
fyrbrd
May 7, 2010 05:03 PM
