Power Steering and No Brakes - Should be Easy, Right?
this truck runs a hydroboost break system. dieselengines by nature do not produce enugh vacuum to use a vacuum assist booster. so we need to have either a big vacuum pump or get assist from a different sorce. powersteering pumps have the ability to produce large amounts of both flow and pressure and that is why it is used. If you need more help to clarify it let me know
OK, good to know this. Also time to review the manual. So, how bad is the braking if the belt fails while towing on the highway? Is this a life/death thing or can I get the truck stopped OK?
Steve
no power steering and no brakes
I have the same problem execpt when mine went fluid sprayed everywhere. I started the truck and drove about 5 feet and tried to turn and had nothin. i got out to look under the hood and there was fluid everywhere. it was dark out but i think the fluid is red. that is power steering right? so what do yall think? power steering pump?
I use my truck to pull a horse trailer, and with horse injuries etc we have not used the truck in two months. Batteries were almost dead when I went to start it. Got it started, but the battery light is on, and now I don't have power steering or brakes. Can it be related to the battery at all? I had this a couple of years ago and had a new alternator put in for the battery and everything was fine. Hard to believe the alternator would go again in two years though
