Steering Wheel Upper Plastic
I have a 93 F150 and I would like to change the rubber boot on the automatic shifter and install a new bulb for the OD indicator on the end of the shifter. I need to remove the upper plastic on the steering wheel but I cannot see how to remove with without removing the steering wheel. Can anyone tell me what I am missing? Thanks
There are screws in the lower half of the steering column cover. Also the ignition lock cylinder needs to be removed, although I have replaced the shift boot with out doing so, but it's difficult. To remove the lock cylinder turn it to the run position and press the pin on the bottom, which is accessed through a hole on the lower cover.
bigpumpkin
12-13-2002 04:01 PM
