AFE Blade Runner Manifold....
on
this could be good..i found it on another site..as of yet its still not released to the public yet.. its like the CFM+ but better..flows more air and also has 5 water ports for cooling.... price is $375.
i think i found a new mod..
- Lower exhaust gas temperature (EGT)
- Unique airflow path with MDV Technology
- Proprietary internal bolt design - quaranteed to not deform and leak
- Cast A356-T6 aluminum construction
- Up to five port pads
- Custom black-zinc finished steel bracket for OE wire harness
- Faster turbo spool-up
- More horsepower
- Increased low-end torque for more towing power
- Improved boost pressure
- Stainless steel hardware
- Some ports with 1/8" NPT pre-tapped threads
on
Just to let you know, that part of the description is for the Cummins, as AFE didn't release a description of the 7.3L part yet. I'm sure it'll have the water ports, though just not the neato wire harness bracket.
I'm more interested in the boost bunny thong pic on the right....lol
the way it reads its for the 7.3..then at the bottom of the page it shoes the one for the cummins...
here is another link from another vendor..
AFE BladeRunner 99.5-03 7.3L Power Stroke | Intake Manifold | 99-03 7.3L Power Stroke | Ford Power Stroke | Diesel Power | Performance Truck Products
The "internal bolt design" gives it away, that's an issue with some older Cummins intakes, Specifically talking about 2 of the mounting bolts IIRC. Notice the other link doesn't mention it. Looks interesting, but shows none or only one water/meth ports. Wonder if they are going to dyno test it or just rely on marketing like some other parts....
[Edit]: Looks like most of the design was geared towards balancing airflow between the heads. I wonder if the passenger side actually gets less airflow than the other bank...
Didn't the passenger side bank have more failures in the engine-fail survey?
F250army45d
06-27-2010 05:40 PM
