84 f350 to 96 f150 cab conversion need advice
hey guys
doing this conversion tomy '84 f350 diesel cab is shot
got a 96 f150 cab and front mint
need to know if anyone in here
can give me some pointers on the wiring side
so all the instrumental panel and the climate controls
i will have some more pics as i go thanx in advance
If you can weld, I have a great, almost painless solution for you that doesn't require you to buy anything.
Remove your old cab, and strip out the wiring harness, dashboard, steering column, and heater core assembly.
Strip out the dash, column, giant aluminum column mount, heater core assembly out of the new cab.
Weld in the original cab's steering column mount into the new cab and mount the original column.
Install the original heater core assembly if it fits in the hole, if not, install the new one. The wiring is almost the same and I can dig out the diagrams if you need them. The only thing that's powered really is the blower motor anyway.
Install the original dash, wiring and such into the new cab, and install the original a-pillar trim as well.
Leave the rest of the new cab intact interior wise, as there are minor differences in mounting, seat belt bolt holes for the shoulder belts, and so on. All you're really changing is the dash and the stuff inside it, the column, and the pillars.
Obviously you could paint the interior plastic of the new cab to match the old dash, or paint the old dash to match the new trim, or paint everything the same color that you like, if this matters to you.
By swapping over the original dash and column (requires a little welding for the bracketry) you can minimize your wiring to just worrying about the heater core assembly.
The 96 F150 cab's wiring is going to be extremely different. It has an electronic speedo which requires a PSOM module and a speed sensor on the differential - your original truck has a mechanical speedo connected to the transmission. The clutch and brake circuits are wired differently, the computers are for certain going to be wildly different and not compatible, and the body harnesses also will be incompatible.
As much as I love playing with wiring, I'd swap the dash as a unit because it would be the least amount of work, I think.
thanks brad i wanted to swap the whole cabin... so i got to figure out what to do as far as the wiring and the climate control...and speedo
i will look @ PAINLESS i used them for other and they work perfect
on the race car
