Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1983 F600 Dump trailer
Old 01-20-2010, 03:27 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Numberdummy has some of the books for the F-600 up range of trucks, I'll give him a heads up.
Old 01-20-2010, 04:43 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Ahlkey
I am new to the forum and it certainly appears like a great place to find out information. I have a Superduty F250 with the V10 engine but recently located a nice 1983 F600 with a dump. However, cannot find out a lot of information on it. The sticker says GVR of 16,500 with rear axle at 11,000 and front at 5,500. It has the 370 2V engine with the PTO on the manual transmission to operate the hydraulic's. What I would like to know is what what this truck weighs, the actual payload, and the GCWR capacity? The truck was used by a hospital and graveyard for dirt and plowing, has low miles, and garaged in doors (no rust). Local Ford dealer was not very helpful.. Thoughts?
On the Certification Label is the GVWR which refers to this: Gross Vehicle Weight Rating.
The GVWR is actually a safety rating, as Ford says: If the GVWR is exceeded, the Warranty is void.
GVWR: The actual weight of the vehicle, the driver, any passengers and cargo should not exceed the GVWR.
The VIN will not have specs related to the GVWR. All it will have is F60 or something similar. These are the 4th thru 7th digits.
The MODEL code (when decoded) defines the GVWR, and is found on the bottom line of the Certification Label.
Old 01-20-2010, 05:58 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
If this was a dump truck since the truck was new, the truck was sent to the body company from Ford as an incomplete vehicle. As such, Ford did not set the GCWR. The body company completed the vehicle and was responsible for installing the completed information sticker showing this information. Chances are that sticker is gone because the body companies were bad about using cheap stickers.
Old 01-20-2010, 07:19 PM
jsimon724's Avatar
jsimon724
jsimon724 is offline
First, GCWR is going to be equal to GVWR of truck (16500) to GVWR of trailer (10000) = 26500. Doesn't matter if you only load 7k on the trailer.
Second, take your truck to your local Cat scales and get the actual weight on it. Subtract that from your 16500 GVWR and you'll know what your payload is.
Old 01-20-2010, 09:19 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
The best I can remember about all F-600s can be registered for less than 26000 lbs
A lot of rental companies have them for weekend warriors without CDLs
The truck is capable of about 8 ton payload depending on state laws
Old 10-17-2018, 10:34 AM
Eric Watson's Avatar
Eric Watson
Eric Watson is offline
Wink 1983 Modified Ford F600
Depending on what is done to the truck, the scale weight is about 5800 stock. However, you might want to take it over any scale. My F600 was modified. A hydraulic boom with a 30 foot reach and 4000 pound capacity was added, a 10 ton winch under the bed and the deck was shortened. I just picked it up for 3000 and will be going over a scale soon. But the way it drives it feels like it weighs about 10000. My ford F500 4bbl, 4sp trans, has a single speed axle. The deck was modified and lengthened so the whole truck empty weights 9960. ITs max is 16000.
Old 10-17-2018, 10:46 AM
Eric Watson
Any personal vehicle, no matter what the weight is, does not require a CDL. The reason the State Patrol and other Law Enforcement Agencies are trying to enforce something that does not carry a law to support it, is to keep people who do not work for companies off the road. Also, the CDL allows the officers to stop you and pee test you any time they want. Inspect your vehicle without a search warrant and more unlawful activities. You do not need a DOT number on your truck unless you are a business and the truck is listed on your business. I drive any vehicle any size that is licensed to operate on any road without a CDL. Even Semi tractor. I operate with out a CDL.
Old 10-17-2018, 04:06 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,583 Likes on 1,291 Posts
Welcome to FTE.
Eric I think you need to do a little more research on the CDL. You can certainly drive what you want, but if you are driving a vehicle with a GVWR of 26001 or over, and you do not qualify for one of the several exemptions, you are required to have a CDL.
The thread you are commenting on is from 2010. Feel free to start your own thread either here or in any forum consistent with the subject you wish to address.
Old 10-17-2018, 10:49 PM
Eric Watson
Wink
Originally Posted by 85e150six4mtod
Welcome to FTE.
I am 55 years old and have done plenty of legal research. Where ever you have learned your part is great. Washington State the CDL requirement is now 16000 pounds. However, if you own these type of vehicles they assume you own a company and are forced to participate in the DOT number along with their Federal Safety what ever. As a personal owner of a 68 F700, a 1970 F500, a 78 F700F and a 83 F600 as well as a 62 Chevy 60....each over 16000 gross do not need a CDL. Commercial Drivers License is for Commercial purposes. Commercial consists of a company in which transports products for itself or other. However, there is a loophole in which, if you own these vehicles and the items you move on them is yours, for what ever reasons, you do not need a CDL. I have discussed this for several years with WASP and they lose. Every time. I have studied law for 6 years as a hobby and am not an attorney or paralegal. But I know what I am talking about. Such as Trump not paying taxes of several million. He says to Hillary...I took advantage of your loop hole. Like I said before, the only reason for a CDL is to invade your privacy, create another avenue for monetary gains and restrict the public from working as a free enterprise.
Old 10-17-2018, 10:55 PM
Eric Watson
If the logs are yours and no matter what the weight is, you dont need a CDL. You really need to understand the difference in Commercial and non. Non is person owing the vehicles regardless of the weight capacity. Commercial is working, driving, being paid for a service. Not a person owning a commerical weight vehicle
Old 10-19-2018, 05:30 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
Welcome to FTE.
I couldn't REP you again. It is evident this poster has a one track mind.
The claims that it invades privacy are absurd. In fact in a recent court decision the State Supreme Court wrote in their opinion that the defendant's argument was absurd. I giggled when I read that.
By the way, the regulations for hours of services, vehicle maintenance, driver qualifications start at 10,001 pounds. Oh, and the regulations includes hazmat requiring a placard or 8 more passengers. When I talk to drivers, especially those are obtaining their CDLs I remind them that they are professionals. When I contact them I expect them to act like professionals.
FordTruckGuy96
15
02-04-2022 08:36 PM
Grooms1983.
09-04-2015 02:40 PM
racingjoe66
Large Truck
05-26-2015 08:45 AM
imjstsitner
Large Truck
03-12-2015 06:44 PM
squarethumps
426
01-02-2014 12:40 PM
Quick Reply: 1983 F600 Dump trailer
