Need to straighten my steering wheel.
Setting the toe is pretty easy with a helper, if your adjuster sleeves are free.
1: Drive truck somewhere level. Drive staight back and forward a few times, make sure that the steering wheel is set wherever it makes the truck go straight.
2: Adjust sleeves equally, one side shorter, one side longer) to get steering wheel centered. Do this in 1/4 turn increments; check it by starting the engine and drive forwards and backwards.
(I'm pretty sure that the tie rod attached to the knuckle has right hand threads)
3: Adjust/check toe. Get a helper and tape measure and measure from the tread centerlines of theleft and right tires. You will want the front of the tires to be slightly closer together than the back of the tires. - about 1/16"
Done!
To tell you the truth, nless you are doing some suspension work, frame unbending, or bent rear, you can't really mess up tany other settings on these trucks. Get the toe-in set right and don't even bother with the alignment shop.
Done!
I thought it was the other way around, that the front of the wheels were supposed to be a tad wider.
To tell you the truth, unless you are doing some suspension work, frame unbending, or bent rear, you can't really mess up tany other settings on these trucks. Get the toe-in set right and don't even bother with the alignment shop.
Do as M.L.S.C. suggests to center wheel. I returned from an alignment from hell and had my wheel to the right. I turned the driver side facing from the front of vehicle down 1/2 turn. The passenger side 1/2 turn up. It straightened it right up. I have since had another shop do a real alignment. Since your wheel is to the left; you need to do the opposite of what I did.
wrd0225
08-23-2016 04:17 PM
NFLEagles1
15
10-25-2011 06:48 AM
