1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Gasoline in Diesel Tank...
Old 01-15-2010, 11:12 PM
fordtech08's Avatar
fordtech08
fordtech08 is offline
Originally Posted by flamebuster
My question would not be if it is bad for the engine but what will happen during regen? For the cost of the vehicle I am more prone to lean towards caution since my wallet isn't that full.....
your truck doesn't go into regen
Old 01-15-2010, 11:32 PM
ke6zmy's Avatar
ke6zmy
ke6zmy is offline
Or, you could have it towed to the local Ford dealership, they can remove the tank and then the diesel/gas mixture from the tank, flush the system, send the contaminated fuel to the local hazardous waste disposal facility, and put fresh fuel in. It cost me almost $900.00 when an employee put in about 3/4 of a tank of gasoline several years ago.
Old 01-16-2010, 11:54 AM
tm0231009's Avatar
tm0231009
tm0231009 is offline
Guys thanks for all of the help nad information, if it was my truck I would just run it and keepo topping it off but it's dad's so I don't know what he will want to do, I will keep everyone updated incase this happens to other people.
I ran the 2 cycle ashless motor oil in my 7.3 for a while...is this what some of you are talking about, or does the 6.0 use a different kind...still not familiar enough with my own engine yet?
Old 01-16-2010, 12:00 PM
Tom's Avatar
Tom
Tom is online now
fordtech08, can you tell us why this is a bad idea with a 6.4L truck?
Old 01-16-2010, 02:18 PM
fordtech08's Avatar
fordtech08
the injectors and high pressure fuel pump don't like gas the pressure gets up to 24,650 psi
Old 01-16-2010, 02:51 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,076 Likes on 978 Posts
There's always the old fashioned siphon tube.... fill with diesel and go.
Old 01-16-2010, 05:45 PM
sandmanf250's Avatar
sandmanf250
sandmanf250 is offline
just run it with some
2 stroke and don't worry about it. i had a kid at a gas staion put 8 gallons of gas in my 03 6.0 before i caught it. did exactly what i'm saying you should consider doing because my truck now has 162,000 on it and i have only replaced the icp sensor.all stock and runs great.
dsmall54
2017+ Super Duty
69
04-24-2023 12:21 PM
Brother Hec
General Diesel Discussion
06-06-2018 09:13 AM
dsmall54
04-11-2017 08:15 PM
ugh3012
02-06-2016 05:35 PM
carboy400
15
03-29-2008 01:18 PM
Quick Reply: Gasoline in Diesel Tank...
