Is this too expensive? And is it worth it?
Total
Description Amount
Complete full custom 4 inch exhaust system. 988.00
Custom 150 HP tune with Fuel economy, transmission setup, DPF issues resolved, Programming and tuning with licence.
Vehicle has custom tuning. ANY updates from dealer will overwright the tuning file that you have. It is YOUR responsibility
to make your dealer aware as to NOT reflash your ECU.
980.00
Evac and recharge A/C System- pressure test and check for leaks 130.00
EGR System with billet blocker plates and coolant bypass. 525.10
Fuel filter kit with installation and frame rail filter assy 128.40
Oil Stand tubes, Oil stand Pedestal tubes, O rings. 294.10
STC Fitting Upgrade to solid steel, With removal and install 205.11
Remove turbo assy, remove intake assy,Remove lower intake assy,Remove water neck,Oil filter housing,Fuel filter
housing,Down pipe, Up pipe, Billet blockers, coolant bypass, all wiring, Boost control, FICM unit.Modifications and all
installation, Remove rack assy, remove cab assy, remove all steering shaft assy, all up and down pipes, heads, coolant,
radiators, intercoolers.
3,080.00
Black Max Head gaskets 688.30
Machine heads, Magnaflux, Resurface 366.40
ARP Head studs 691.30
Oil and filter change with oil supplied 138.00
GST@5.0% 410.74
PST (MB)@7.0% 575.03
Total Tax 985.77
$9,200.4
This is a quote I got, my truck is in mint condition and I would like to keep it for a long time, I know this would wake it up a little, but is it worth it, would this make the truck more reliable? Keep in mind this is in Canada and we pay more for everything! This quote is from Walls costom rod, so from what I have been hearing this shop is the best at doing this in my neck of the woods
So the total is $9200.00
Description Amount
980.00
3,080.00
GST@5.0% 410.74
Total Tax 985.77
$9,200.4
Well there is almost $1000 in tax included that price, so at $8200 it is probably a little high. But looking at what they want to do they must have some experience with 6.0's, so I would say it is better to take it to somebody with experience than somebody that is cheaper with no experience. Also I think I would want OEM head gaskets.
waiter, check please.......
that, and the head gaskets give me pause.
truth is, it clogs my bull**** filter.
$9,200 to fix something that isn't broke?
settle down, open a beer, close the wallet, and read
a bit here. there are some smart folks here, and they
have enough information to boggle your mind for a while.
if this ride is pristine, and no problems........
change out the studs, change out the alternator for a dc power,
get a tune from matt for $500 or whatever he charges, and
JUST DRIVE IT, with a scanguage to watch the numbers.
under $2k, and you'll love the way it works.
most of the folks on here will echo the same advice, over and
over again. listen to it. not naming names, but if m-chan, cheezit,
or bismic suggest it.... just do it.
Where in Canada are you? Some of those prices are way out of line, even for up here. PM me. DO not even think of using anything other than OEM head gaskets unless you want to tear it down it all over again.
