Whats This Noise????
Old Jan 11, 2010 | 11:51 AM
baby2000's Avatar
baby2000
Well i have an automatic 99 f-250 and i just noticed that when i get to s stop and then go again i hear a little clunk coming from the back and then kind of a little jurk forward.. I dosent do it all the time. Does anybody know what might be casueing this?
Also how offten do you guys change your oil?
Old Jan 11, 2010 | 12:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This could be your fix. Check this out. LINK
Old Jan 11, 2010 | 12:12 PM
tdpower's Avatar
tdpower
Sounds like you need to grease the slip joint in the driveline. I'm sure Rick will fix that link. Make sure to choke the tires as it will roll when disconnected.
Old Jan 11, 2010 | 12:16 PM
knight60626's Avatar
knight60626
had this same problem you described on chev p/u and it ended up being the rear brakes sticking, I replaced the slide pins and the pads and that took card of it.
There is also the possibility that it could be in the rear end but in my experience it would be really noticable going from reverse to drive and vice versa.
Old Jan 11, 2010 | 01:09 PM
BillyBob69's Avatar
BillyBob69
What he said. Start with the easy fixes first. Chock your wheels to keep it from rolling, remove the boot and grease up the slip joint. Pretty common. If that doesn't fix it then start looking at your brakes, remaining drive line, diffs.
Old Jan 11, 2010 | 04:48 PM
jcrammell's Avatar
jcrammell
Slip joint is the issue. Take it from Pete and I and probably others on here to. Chock your tires. Your truck will roll on you. Not fun, just ask Pete.
Simple fix that costs what ever the cost of a thing of grease. Mine was like $2.00 and half an hour of my time.
Old Jan 11, 2010 | 06:54 PM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by baby2000
................................Also how offten do you guys change your oil?
Well, that's a broad question. You other was answered, but this will get you lot's of different opinions. I change mine every 7K, but I am using Syn. oil and Blackstone says I can go more, but 7K is good for me. When using dyno oil, I would change it every 4-5k. Some running extra filtration systems are going 10k or more on an oil change.
Old Jan 11, 2010 | 10:32 PM
drillerdan's Avatar
drillerdan
I change my oil and filter every 5-7k miles and use Rotella synthetic oil.
Old Jan 11, 2010 | 10:58 PM
schlepprock250's Avatar
schlepprock250
i had the same clunk,the slip joint needed to be greased,but the center support/carrier bearing was also bad.
