Choke Tubing 351M/400
Forgive my terminology blunder. I don't know what you call the apparatus but it serves as a thermal coil in the emmissions port of the intake manifold and has one tube running to the choke and the other running to the back of the 2V carb. I have never been able to get one disconnected from the carb without distroying the hot leg going to the choke. It just crumbles in my hands...rusty and brittle. Anyway, none of the local parts stores seem to have them. It may be because I don't know exactly what to call it. Can anyone out there tell be where I can get one or how I can deal with what I have?
Damon
'79 Lariat
Damon
'79 Lariat
Thanks for the information. I will pick one up and give it a try tonight. I found a kit a NAPA store but it required a hole to be drilled into the exhaust manifold and tapped with a nipple for the tubing. I was hoping for something that would work with what I already have...it sounds like what you describe is what I am looking for.
Damon
Damon
Yes the instructions say to drill & tap into the manifold, but actually the adapters supplied (3/16 & 7/32)simply go into the existing hole at the choke riser plate. Select the closest and knock it in place. I don't think you have to do any drilling on the Ford.
Phillip
Phillip
'77 F100 Custom
12-06-2016 09:01 AM
boomer202
01-11-2004 09:41 PM
