94 superduty towing
94 superduty towing
Hi,
I posted thisin the 87 to 96 forum someone said I might have better luck down here.
I recently bought a 1994 Ford Superduty Dump <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_0_0>truck</NOBR>, I would like to know the maxium towing capacity and the max GVCWR. The truck has 7.3L diesel IDI, 5sp manual 2wd, 5.13 11k axel. it did not come with an owners manual. I bought one from helm but it does not seem to cover diesel engines. The truck weight is approx 8560 pounds acording to the scales at a sandpit. also the door jamb has a GVWR of 15K, but have been told it is a 14,500 truck.
thanks
Chris <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
thanks
<!-- controls -->
on
what are these ratings with the auto PLC?
in wiki,under 9th gen 1992–1996/1997 trucks is:
Models:
* F-150: 1/2 ton (6,100 lb GVWR max)
* F-250: 3/4 ton (8,500 lb GVWR max)
* F-250 HD: 1992–1997 Heavy Duty 3/4 ton (9,000 GVWR max)
* F-350: 1 ton (10,000 lb GVWR max)
* F-Super Duty: 1 ton plus (15,000 lb GVWR max)
i assume the "super duty" is the f450 correct?
EDIT: oh,nevermind that last question.yup they are f450's cab/chassis.this info is under the eighth gen trucks.
http://en.wikipedia.org/wiki/Ford_F-Series
Models:
THE BLUE HEAP
12-25-2009 08:18 AM
sarahlou
26
04-18-2009 08:45 PM
