what 4 speed trans will work in place of C6
E4OD is the only one in that bell pattern.
AOD/AODE/4R70W are in SBF bell pattern with an expensive adaptor required on top of a beefed trans.
The E stands for electronic, so you would need a stand-alone computer, at $500+, to run the trans.
Trans links fwiw:
E4OD and 4R100E Performance Products
TCI - Ford AOD, AODE and 4R70W
E4OD, 4R100 Transmission from PATC, E4OD, 4R100
You can add an OD to the tail, but it's pretty spendy too if you buy new:
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
They say $4 gas is coming back, but even with that price, you may save gas but it's a big question as to if you'll save money.....
Trans links fwiw:
Just recently checking into this.
Speaking with hughes performance. Just got a email back today. Like mentioned before E4oD tranny is you only choice in oem form. I know their are some upgrades to chevy tranny's but very expensive with bellhousing changes. So for our application is E4oD is our situation. Also your gonna need a electronic controller. I know they are expensive also. Hughes suggested to me a full manual valve body in a E4oD about $2500.00 with converter and core charge. this is a new transmission built up with full manual and Hd towing converter. I like a full manual valve body but some don't. I like to shift gears! So I'm thinking of going this way once the income tax kicks in. Any question drop me a PM or I can send you the email I got today from hughes for my application. Good luck and check back in with me. WE don't have much for salvage yards and used parts out here and so I usually end up getting shop new and built up. wyoming is great but not so grate on salvage parts. Have to ship in used parts can be expensive especially if its a bad used part. EBay can be a beach!!
shanes_cool
20
04-14-2019 11:36 PM
Thudpucker
05-17-2009 06:26 PM
elb
05-03-2005 09:56 AM
76 F250 4X4
10-28-2003 10:00 PM
79blackbeastdw
11-13-2002 01:48 PM
