5th wheel towing questions
We're looking at getting a 5th wheel to full time in that is going to put me overwieght per the Ford recommendations. The trailers we're looking at are in the 12k range dry, 15k GVWR. I have an '02 F250 4x4 Crew Cab Lariat so my Ford recommendations are 20k GCWR, 12.8K for the trailer. I'm not concerned about the drivetrain being able to handle this, we all know it can, but want to make some supesnsion and brake upgrades so the truck can better handle the load. I've already got 10 ply tires on the rear axle so I'm fine on pin weight. I plan to add cryo'ed rotors on the front and an airbag system for the suspension. Is there anything else you guys would consider necessary for towing 15k?
We will probably be moving very infrequently, the plan is to live in it here after selling the house while I get my business sold off and then to move it to SW Colorado, where we plan to stay. We may take some interim trips before the big move though.
Find out what the pin weight is for the 5th wheeler you are considering. Our 31' 5th wheel has a pin weight of about 1,500 lbs. Then when you add in the passengers, fuel, and all the other stuff in the cab & bed I'm ussually around 2,300 pounds of cargo weight.
I have been very happy with the airbags and onboard compressor. Definite ride improvement and truck leveling. The cryo treated brakes are also a good upgrade IMO. I was glad to have them when my trailer brakes wet out.
Some additional considerations.
1. Teconsha P3 brake controller - very user friendly
2. Bilstein Shocks
3. 6.0L Trans Cooler
4. Van Turbo
2. Bilstein Shocks
4. Van Turbo
Published pin wieght is 1760. I've done the Bilsteins and have a Wicked Wheel I need to put in. I get a little flutter pulling a steep grade with the 7k bumper pull TT we have right now. Trans cooler is definitely something I need to add. We just did a trip to Co and back and never got over 180* on the trans but, we were also pulling with outside temperatures of 30* - 60*. I've got a brake controller already, it's not fancy but it does the job.
Do some calculations to figure out your cargo weight. I believe the owners manual will show the max cargo weight around 2,300-2,400 lbs or so. With a pin weight of 1760 that leaves you about 540-640 lbs left over for passenger, fuel & fluids, and any additional items carried in the cab & bed.
Sounds cool, just wanted to make sure you understood the max cargo weight in addition to the GCWR & max trailer weights you initially mentioned. Just wanted to make sure you knew before diving in to the purchase.
For that haul I would also change the tranny fluid if it has been a while. Synthetic Tranny fluid will hold up better in the towing & high heat conditions. Otherwise it sounds like you are right on track with the mods.
I can't wait Adam - forcasted to get up to 25 deg F tomorrow! That would be a 53 degree increase from this morning!
Please don't take this in a bad way because that is not the way I mean it. I love RVs and have been RVing almost my entire life and I turn wrenches on them almost everyday, but even a second rate attorney will have a field day with this type of situation.
Steve
Lord, I hate making a post like that, but having worked as an expert witness in the past, there is no way I can express how vulnerable a person is who exceeds the manufacturer's recommendationz. It only takes one question from the opposing attorney during the deposition to win the case and if there is a death -----
Steve
Steve
We had one locally where a little seven year old girl died in a crash when they came down off the Interstate loaded too heavily and couldn't negotiate the turn at the bottom of the ramp and I have had two customers who lost their brakes on grades, one an F250 pulling a large fiver way over his ratings.
The only way he lived was no one was coming up the hill in the oncoming lane as he came down it. This stuff really does happen and I admit, I am conservative as the devil when it comes to weights. I am involved in the industry and I care about RVers safety.
Steve
