#30 fuse keeps blowing!! - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 04-16-2010, 12:10 PM
Nick 99's Avatar
Nick 99
Nick 99 is offline
Nick 99 is gaining momentum as a positive member of FTE.
Can someone post up a diagram of the fuel heater relay circuit?
Nick
  #47
Old 04-16-2010, 01:17 PM
Sheldon Plankton's Avatar
Sheldon Plankton
Sheldon Plankton is offline
Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.Sheldon Plankton has a good reputation on FTE.
Originally Posted by Nick 99 View Post
We seem to have an inherent design problem in the Fuel heater design. The fuel heater is fed from the same power source that also feeds vital engine devices. It seems to me that if we were to resource the the power to the fuel heater relay, and use a separate relay to control the heater curcuit. That way if and when the heater fails, it would only blow the fuse that powers the heater and nothing else.
Comments?
Well since you asked, my comment is that it is an unnecessary hassle just to keep a worthless gadget on your truck. See Chris' earlier comments about where the fuel is most likely to gel.
  #48
Old 04-16-2010, 04:20 PM
Nick 99's Avatar
Nick 99
Nick 99 is offline
Sheldon,
As you can tell by my fellow FTE friends, we like a challenge! Beside if the mod could be done easily, then we not get the code when we simply disconnect the heater.
Nick
  #49
Old 01-08-2019, 11:25 PM
Rafael Sanchez IV
Rafael Sanchez IV is offline
Rafael Sanchez IV is starting off with a positive reputation.
Thank you
This forum is fantastic, thank all of you for your knowledge and sharing your experience. My 30 amp fuse on my 99 f350 power stroke kept blowing. Fuel bowl heater element was the cause. Thanks again.
  #50
Old 01-09-2019, 01:31 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Welcome to FTE!
Did you replace the heater or remove the harness? Fuel bowl heater is really not needed in a warm climate like ex-Charger land. Condolences on losing the team to LA, btw. As a Raider fan I'm staring that in the face when they sail off to Lost Wages.
An alternative is to leave all intact but pull the connection inside the bowl and kink the wire so it stays away from the terminal. That way the heater can be reconnected if needed, and the "water in fuel" light still works.
Ryan313
02-28-2017 09:45 PM
J_Ringo
1999 to 2016 Super Duty
02-27-2017 10:01 AM
briscoe112
06-16-2016 04:41 PM
james.jefferson
01-14-2012 12:33 PM
sflem849
17
05-19-2011 10:11 AM
Quick Reply: #30 fuse keeps blowing!!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
