98 Expedition 4.6 Windsor noises
my 98 Expedition 4.6 Windsor is making noises, starts out as light tapping when first cranked, as it warms up tapping gets louder and harder. When it is being driven, it runs pretty smooth, stumbles a little bit which I think is fuel injectors, 224,000 miles and have never had injectors changed. Planning to do it after Christmas is over. Anyway, when I come to a stop, the tapping is pretty loud and hard. Have had several people tell me it was everything from timing chains slapping to main bearings knocking, to the exhaust manifolds maybe having a broken stud. So far it has been too cold and raining most days to check manifolds. Bottom line, it still runs ok but sounds like my grandfather's old diesel tractor. Any clues what causes this? Too broke to take it to a shop so I do my best to do my own repairs.
You're kind of down to exhaust manifold leaks as the problem, although I can't be 100% sure about it. You can try to narrow down the noise location further by using a 3 foot (or so) piece of hose. Put one end to your ear and move the other end around to various places around the exhaust manifolds to see if you can pick up loud spots. You cannot feel for leaks due to the radiator fan running all the time.
Yes it is very common for your model year. The best way to check the studs, or use the hose as I mentioned is by removing the plastic wheel well cover. This allows you to look right over the top of the front tires and get in there real nice.
The only problem I see with the diagnosis so far is that exhaust leaks at the manifold generally start out loud when cold and get quieter as the truck warms up. They also rarely sound like a heavy metallic knock.
I hate to say it but it sure sounds like rod knock to me. They get worse as the engine warms up. It is a heavier, metallic sound. As it gets progressively worse you will see an oil pressure problem but not necessarily early in the failure.
I wouldn't rule out the leaky manifold, just sounds more like a bearing to me.
Good Luck
Good Luck
I do not think you can put a number on that. Everybody has a different definition of "maintained". We also drive mass produced vehicles and tolerances vary to some degree on everything from materials to assembly.
My company truck was well maintained by the first manager who drove it for just over 100k miles. The next two guys were total bozo's and they put another 140k between them. It has 255k on it now and still runs pretty well. It makes some interesting noises now and then, and I'm not ready to drive it cross country, but overall I think it still has some life in it. I had the front end rebuilt and a complete brake job so it rides and drives well. The 5.4 still has good power with tolerable oil consumption of 1qt per 3000 miles.
You just really never know. If it is a rod, I still think 224k is pretty decent. 25-30 years ago most cars were trash by 100k miles.
Light tapping and rattle sounds more like valvetrain or manifold gasket. Have you done an oil change recently? Is the oil level correct?
I might do an oil change, examine the oil that comes out for metal, and cut the filter open looking for the same.
It is extremely hard to diagnose a noise we can't hear.
To me it kinda sounds like timing chains. The chain guides have teflon tensioners that wear out. mine were worn down to the metal and left shavings in the oil pan. Change the oil and run your fingers through the oil (I think mine were made of alum). But I wouldn't rule out the other stuff either...good luck
Gevans17
1997-2006 Expedition & Navigator
05-04-2011 12:40 PM
exp1998
07-07-2009 09:02 PM
