Help! 6.9L Spewwing Oil
background of truck: I have what was a 1984 F250 Single Cab 4x4 6.9L (only 80k original), it now has no body and is on its way to becoming a swamp buggy (headache). I cranked it up to see if this "oil leak" problem my buddy told me about really existed. He said It was blowing the gasket on the oil filter and just pooring every last bit out. I purchased a manual pressure gauge, tightened the (#$#* out of the new filter i just put on it, dumped in my oil, and prayed. Started it.. and the oil pressure gauge pegged all the way around to 120psi and couldnt go farther (im sure it was higher), 10 sec later the gasket on the filter blew and there went several quarts before time to shut her down.
local ford dealer is baffled. says that the motor is "too old to pull up info on"
only plus: we got plenty of oil pressure!! ha
id appreciate anyone willing to point me in the right direction..
In the rear header of the oil cooler where the filter installs there is an oil bypass valve and a pressure regulating valve. I would suggest getting a used oil cooler rear header or complete assy. Then redo the oil cooler orings and gaskets on it and install it complete and see what happens. You could just get the rear header new big $$$$$.
The reason I suggest doing the orings on the replacement is purely peace of mind......
My photo link has the how too for oil cooler R&R plus orings.
something is very wrong there. I would vote for the CDR Valve as well. When i searched it came up more than a few times that it caused excess pressure. Pull it off and see what the condition is. If it is in the condition i think it is, it could very well be all gummed up but i am just a bit skeptical due to there being that much pressure, i would think it would force past the cdr valve "gum" first.It almost seems like there is a blockage right at the oil filter housing and the oil pump is kicking the crap out of the filter seal. Maybe take a look there too.
