3.55 gears in a 6.0?
anybody here...have, or had, a a 6.0 with 3.55s or higher in it?
Ive got an 05 6.0 CC 74k with 3.73s and most of my driving I have minimal weight behind me. and a few times a year i have 3-10k behind it....
So I was thinking about putting in 3.55 gearing for a little better mileage along with a few other mods to help in that department.
and i was wondering if anyone has knowledge on this... it seems like these 6.0s really like to run the Rpms up so i am brainstorming ways to help a little because im not going to drive 65 mph on the free way to save 2 bucks by getting better mileage THAT way.
I will posts some figures, If your truck had 3.73 gears and 285 tires running 2,000 rpm with a final ratio of .7 your speed would be 75 mph. With 265 tires and a 3.55 rear your speed would be 76 mph. My truck has factory 265 size tires on it with a 3.73 rear and if I wanted to achieve the same roll out ratio as a 3.55 truck with 265 tires, I could go to a 285 size, which is not drastic.
If you could find a taller tire with the same width and minimal additional weight your gain would be greater.
The cost of gear change will take a very long time to pay for itself ,
I installed 285/65/18 on my truck from the original 265/75/16, and I noticed a drop in mpg, I didnt want to believe it, but my hand calculations are coming out to about 1.2 mpg loss. I went back to adding PS into the gas tank to help bring the mpg back up, but have yet to observe any differences. So far I am seeing only about 12.7 mpg... And that sucks, but this was also after the july pcm flash to where my mpg took a huge drop.
I remember reading and posting on that thread, I was heading back to the boneyard to pick up a FICM from an 04 F350, and came to find out, that they are different from the 03-04 and the 05 to curtrent. I guess I am going to have to send mine out for a reprogram and just be down for a couple of days.
But yeah, you'll be down for a few days, but when you get your FICM back, you'll be beyond happy with your truck.
Like I said, if I owned a 6.0 that would be my first mod...
