M5OD Diagrams - Ford Truck Enthusiasts Forums
M5OD Diagrams
Old 01-06-2010, 01:38 AM
'90-f150-302-5spd
'90-f150-302-5spd is offline
'90-f150-302-5spd is starting off with a positive reputation.
M5OD Diagrams
Hi there, Ive searched all over and cant find a decent M5OD-R2 exploded diagram. I need to get a few parts but dont know names or part numbers. All ive found is one on supermotors.com. But I belive that's the R1 not R2. Also While on transmission issues, I need a new shift **** (mine has a cobra head currently and it needs to go!) and I dont know where to look as it is press on not screw on. Stock looking or aftermarket is fine, but the cheeper the better.
Thanks, Justin Y.
Old 01-06-2010, 02:08 AM
phoneman91's Avatar
phoneman91
phoneman91 is offline
phoneman91 has a good reputation on FTE.phoneman91 has a good reputation on FTE.
Try this website. You didnt say if you had a 4x2 or 4x4 M5R2.
Manual / Standard Transmission Identification Parts and Diagrams
Old 01-06-2010, 07:10 PM
'90-f150-302-5spd
Hey thanks alot! That helped me find exactly what I needed. I was looking for the shifter seat. Right now my shifter has a ton of play. I also have the part numbers to order it.
Justin Y.
Old 01-07-2010, 03:30 AM
phoneman91's Avatar
phoneman91
The shift **** is a press on. It has straight splines on it. The Ford dealer still stocks them. May have to sweet talk the dealer parts guy though. Probably find a good factory shift **** at the bone yard at a reasonable price .
Old 01-07-2010, 10:20 AM
mike460's Avatar
mike460
mike460 is offline
mike460 is starting off with a positive reputation.
Pony up for a Hurst shifter for it - hands down the BEST money I have ever spent on my truck.
Just my $0.02
Old 01-15-2010, 02:19 AM
southernchaos
southernchaos is offline
southernchaos is starting off with a positive reputation.
have a question i have spent too much money swapping my truck over from 2wd to four wheel drive i have installed a 6 inch lift the chicken wing dana front axle 3inch blocks in the back with add a leafs the truck is a 1994 ford f150 4x2 sport is with m5r2 trans will a 4x4 tail housing and transfer case i bought used out of a 1993 f150 4x4 fit this truck or is the shafts inside a 2wd and 4wd m5r2 trans different please help me with this or direct me to somewhere on this site that can any help will be greatly appreciated
Old 01-15-2010, 02:26 AM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
Justin Y.
if you have a ton of play look at the pins in the shift ball while your doing that seat...
looking at the diagrams you found it should show them, right on the top of the shift tower, going through from both sides into groves cut in the shift ball...thats what gave mine a tone of play...but i did the seat too...theyre cheap
Old 02-05-2010, 01:56 PM
keydr's Avatar
keydr
keydr is offline
keydr is starting off with a positive reputation.
I agree with Mike. The hurst shifter was the best thing I could have done in mine. I love that thing. Well did love it. It's sitting right now with a blown tranny. Too much fluid loss due to those pesky little plugs on the shifter housing. Do yourself a favor and replace them.
Old 03-17-2010, 11:44 AM
snipAR-15
snipAR-15 is offline
snipAR-15 is starting off with a positive reputation.
Just my $0.02
Have you had any issues adjusting the hurst shifter?
Old 03-19-2010, 02:56 AM
'90-f150-302-5spd
Ive got too many other things I need to put money towards to buy one of them hurst shifters. Im not looking for it to shift like a mustang. But I would like to know the cheepest place to buy a whole rebuild for the shifter (pins, seats, and whatever else).
Old 03-22-2010, 12:50 PM
mike460's Avatar
mike460
mike460 is offline
Well not really the adjustment of the shifter - but I did have some issues when I installed it. My trans had been rebuilt, and it had the larger shift pins installed to try to correct the stock shifter, so I had to do some grinding on the shifter adapter that bolts between the shifter and the shift tower on the trans - the notches in it were not big enough for the aftermarket pins which would not allow it to sit in the tower far enough. This caused it to be incredibly difficult to get into 5th and reverse, and would pop out of 5th. I still don't have it perfect as it "buzzes" a bit in 5th but it isn't something I can't live with.
brandonf150
02-28-2017 02:35 PM
Thefordbuspeople
03-07-2016 10:31 PM
the droom
1968-2013 Full Size Vans
09-22-2015 08:56 AM
Motorhead351
WTB - Parts & other
08-22-2015 08:02 AM
'90-f150-302-5spd
12-15-2009 08:10 PM
Quick Reply: M5OD Diagrams
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
