Frozen (literally) cylinder #7. Ford says warranty now void!
UPDATE on Jan 13, 2010: See Post #356 for new pictures and notes from Ford
I'm sick to my stomach right now. My truck is a bone stock 2009 F-350 with 50,000km on it (30,000mi). The truck has been used 90% on the highway and 10% on remote off road sites. All regular maintenance has been performed at the correct interval.
The truck had just finished a 1000km highway journey and was parked over night in very cold weather (-35C). The next morning the truck would not turn over. It was towed to the dealership and they said cylinder #7 was completely full of water which had frozen solid to the point that the motor would not turn over! None of the other cylinders exhibit any sign of water penetration. The dealership says the engine warranty is void and I am now on the hook for a brand new 6.4L on my 1 year old (almost to the day) F-350.
The dealer found no traces of water in the fuel. How the hell did water get in there, and how the hell is this MY FAULT?!?!
Last edited by Red_Stallion; 01-15-2010 at 12:17 AM. Reason: Updated with directions to new pictures
This is when you call the Ford number in your owners manual. If you don't have a tuner there is no reason for the warranty to be voided... if there's no water in the fuel it's not the fuel station's fault either.
Are there any traces of water anywhere else? When you tried to start it did anthing else get busted?
Call the 1800 number and get ahold of Ford and keep complaining.
If the truck had been submerged wouldn't there be water in the other 7 cylinders? Also if it was that cold, could your coolant be to blame? Only way in I can think of is thru the head gasket.
Unless you got pretty crafty with a syringe and catheter tube and worked some fancy faniggling past the turbos and valves?
Only other thing I can think of, and this may be a little far fetched, is scavenging. Perhaps (this is a long shot) as you shut it down that single cylinder sucked in snow thru the tail pipe and it vaporized/ liquified and somehow got sucked in.
I mean there is only 3 ways in: intake valve, exhaust valve, head gasket. Honestly thats freaking wierd.
If they think is was submerged ask them how you get water in only one cylinder and not the other 7.
I'd think the head gasket on #7 and allowed the coolant in there. The heat from the cylinder being hot may have boiled off the glycol and allowed the water to freeze.
Get in contact with Ford.
We can't get into legal stuff here, but suffice to say that you should be prepared to do so.
They said no water in the fuel, something which you would definitely be responsible for, which leaves coolant. It would be a simple test to check if the ice was from injected water, or was from engine coolant. Was that test conducted? If it is coolant, a strength test needs to be performed. Are you certain that the proper concentration of coolant was maintained? Are you certain that only Premium Gold coolant was used?
They may argue that you parked it in -30 weather, and didn't plug it in per the owners manual. If the coolant freezes in the block, that might push it into the cylinders.
I would like to know for sure if it's coolant. It could be argued that a leaking head gasket hydrolocked the cylinder. Ford should cover that.
I don't know what else to say except that I feel for you, urge you to stick up for what's right, and let us know what happens. This is not how we like to meet new users on FTE.
Been in contact with a couple 'higher ups' at Ford and they are 'looking it over'
I would like to know for sure if it's coolant. It could be argued that a leaking head gasket hydro-locked the cylinder. Ford should cover that.
Will find out about performing that test.
New member yes, but been on here 'lurking' many times before.
