C6 crossmember for a C6?
The last year for Ford-O-Matic was in 1961, and then was only used in F100's with 223 I-6's.
Everything else thru 1967 used Cruise-O-Matic (C-O-M). 1968/72: C6.
C8TZ6A023A .. Rear Engine Mount Bracket (crossmember).
Fits: 1965/67 F100/250 352 2WD C-O-M / 1968/72 F100/250 2WD 360/390 C6.
C5TZ6068A .. Rear Engine Mount (Rubber Insulator)
Fits: 1965/67 F100/250 2WD 352 C-O-M & M/T / 1968/72 F100/250 2WD 360/390 M/T.
C6TZ6068F .. Rear Engine Mount (Rubber Insulator)
Fits: 1966/67 F100 352 4WD M/T / 1968/72 F100/250 360 4WD M/T.
Fits: 1968/72 F100/250 2WD 360/390 C6 / 1968/72 F350 360/390 M/T & C6.
So i am swapping out the original 4 speed tranny & T-case to a C-6/Dana 205 T case in a friends 66 F-100 4X4 Truck.
I understand you can re-use the original cross member and move it back bye grinding out the factory rivets, but after i remove the cross member, what are you guys doing to re-tie the stock brackets back in to re-strengthen the mounting brackets for the trailing arms that are mounted to the frame for the front end?
I guess i could remove the stock cross member to install the C-6 tranny and then re-bolt the cross member back in to re-tie the cross member back to the trailing arm brackets, but it looks like to me the stock cross member then would be in the way of the new C-6 tranny.
Thanks for any info
Rick
Hey Guys!!!!
Thanks for any info
Rick
Thanks for any info
Rick
anybody have a answer????
Highboy74
12-10-2016 05:54 PM
johnson.jeff.a
34
11-07-2015 12:30 PM
ralphhood3
12-03-2014 04:46 PM
Chris Guthro
12-11-2013 07:39 PM
jrockdiddy
12-04-2013 05:18 PM
