Rough Running
Rough Running
Ive got an 06 6.0 f-350 had some trouble awhile back with rough running and no power so i changed to t-stat and put a grille cover on thinking that was the problem but it only fixed it for a little bit and no its back worse than ever. start it up cold or warmed up its got a noticable miss put it in gear and gets even worse as long as you get the rpms above about 2,000 it smooths out it still lacks a little power driving 65 try to pass or climb a hill the whole trucks shakes and slowly gains speed until it downshifts then it okay just low on power changed fuel filters and oil, filled up and added diesel service with antigell didnt make a difference so stopped by the dealer yesterday and they thinking a injector is stuck open. last thing i wanted to hear does anybody have anything to try before i have to spend atleast a 1,000 for dealer to fix it?? im willing to try anything at this point thanks
The 6.0 has so many sensors it virtually diagnose itself.
Do the Italian Tuneup then.
https://www.ford-trucks.com/forums/9...ml#post8298311
no i havent tried a strong injector cleaner " any suggestions" i was running howes lubricate and i tought it was gelling up so i ran a bottle of diesel service 911 and now im running white bottle of diesel service with no change so far. yes my warranty is up ive got 135,000. my code reader isnt showing any codes so im not sure where to start. and this morning i went out to start and it didnt want to turn over it was -2 F when i got off work i put a battery charger on for a bit then went to try it again and i lost all power to everything some how. The cab lights or anything wont come it reset the radio and all so i left the charger on it and the starter is still trying to turn over with keys out im complety out of ideas
on
Does it read CAN? If it doesn't read CAN or it only gets generic codes(which are mainly emission related) then chances are you won't ever see a code thrown on that device.
While our trucks were the first to be OBD-II complaint with the general powertrain. It mainly consists of 6 or 7 sensors and almost all of them are EGR related.
on
Its in some ways very simple and others very complex. Its not bad if you knowo what it is you are looking at and for but by nomeans is it that easy.
an the Italian tune up is not the fix all. I have seen it be the break all before though.
Cheezit is right. At this point chasing your tail. It sounds like you had one problem that has now blossomed into more. You have to step back and tackle one problem at a time. First off, at -2F you shouldn't have 15w-40 oil in it. That's a summer oil. If you already using synthetic don't worry about. If I were in your shoes. I'd get the truck into a warm shop and start looking at the source of why the truck went dead. Load test the batteries, Check over to connections and look for harness chafing. Something caused it to completed lose electrical power. Once you solved that, then you can tackle the rough running issue.
I love this thought process. All the stuff that this thing tell us. can send a person on the biggist goose chase knowen to man.
Ya.. cheezit.... that is why you people who do this daily, have the expertise and experience and have the Ford diagnostics tools earn $$$$ and the rest of us don't.
There is, um, a bit of common sense involved in using the "Italian tuneup".... hmmmmm.... How do I convey that?
Or just wait until the kid with the tuner dial up 1,000hp, 1,500ft lbs of torque, and put the pistons through the block?
LFDavidson
01-26-2015 09:55 AM
91CavGT
63
01-22-2014 05:37 PM
Stevil
3.8 & 4.2L V6
05-02-2012 06:55 AM
preston77
41
08-20-2008 08:53 PM
Green_Monster
01-31-2008 08:20 PM
