Degas bottle MIN/MAX levels...
COuld you guy's refresh my memory, I can't seem to locate it in any of the older threads..but I recall a that Ford put the incorrect stickers on the degas bottle for min/max levels....what is the correct level for coolant in the degas bottle on a 2007 6 litre...?
Did you use a level to verify that the bottle was level and then a micrometer to measure the level accurately?
Don't forget now... you have to correct for temperature, atmospheric pressure, humidity, and also variations in the earths gravity where you are!
Above joke intended.
You are in rare form tonight!
I would add that in order to precisely establish the correct degassed level you should put a vaccum on the system and hold less than 0.1 atmosphere for at least 30 minutes, thus ensuring a liquid collant only measurement. Finally, do not forget that as the temperature changes, so does the size of the degass container and the porosity of the metals so you really need a finite element analysis of the entire system to predict the exact correct level at each temperature....
Mines on "min" when cold, 2003 model.
If you have a "sticker", it is probably correct. The problem was the levels molded into the plastic degas bottle. Stickers were used to correct that.
andym
16
01-27-2017 07:40 AM
rawdeal
1999 to 2016 Super Duty
04-03-2014 06:31 PM
