I cant get a flex spring hose to fit on from the pump to the radiator, the steering box is in the way. and the upper I can get a flex style to work, but would rather have a "OE" fit.
Well I used my superior "presidential engineering skilz" and got some hoses to work(I hope) for the upper, I cut out the long strait part and put a chunk of exhaust pipe in its place. For the lower, I used the first "90" off the hose, than used a piece of pipe to butt a flex hose in for the rest of it. So, tomorrow when I take it to town, we will see what happens.
I couldn't get a flex hose to make the tight 90 between th radiator and the steering box. So that's why I did it this way. Plus I put my 180* mr gasket stat back in, so I know it will flow good. I'm pickin up my 27hp tractor tomorrow, so it should get a little workout so I be able to see hoe ood it works.
