Dual fuel tanks cross filling from rear to front
This has been addressed previously and was a recall but mine is passed that time. The front fuel pump (fuel delivery module) does not work at all (engine won't run). I run the truck exclusively from the rear tank. I want to tee off the return line to the front tank into the line to the rear tank, bypassing the front tank entirely. My question is how much pressure is on these return lines? Can I use barbed fittings and clamps or do I need to use higher pressure fittings to prevent leaks?
I have considered replacing the front pump but I'm a cheapskate. The repair manual said the front tank would overfill by way of the return line if the check valve in the front pump assembly failed. I hadn't thought about fuel reaching the front tank by way of the supply line. Thank you for your reply. I'll likely buy the pump and be done with it. It's a 302 FI.
donskrin
11-30-2015 08:27 PM
predaina
29
03-29-2011 07:07 PM
court1100f
20
07-02-2009 07:50 AM
