broken exhaust bolts..how to fix???
I dont know when they broke but the 2 rear bolts on the pax. side and broken. The last one is broken off flush and the next one I cant tell. I had the engine replaced 26K miles ago. Should I leave this for the pros or what???
Thanks, Slug-O 2004 Ex. v10
I had a broken stud on mine too. I was dreading the project, but finally decided I couldn't really make it too much worse if I was careful. A good set of easy outs, a small angle drill, and a steady hand is what you need. Remove the wheel and the inner fender cowling. At that point, the exhaust manifold is staring you in the face. I think I was lucky, the broken stud came out pretty easily.
Steve
Steve
Here is what took place when I did it myself...
https://www.ford-trucks.com/forums/8...s-project.html
I attempted to do it myself just for the reason that I didn't want someone else to try to do it and screw something up and tell me I need a new head or something. If you are mechanically inclined, have patience, and can be without the truck for a few weeks, it is very do-able with the motor in and the heads on. Like I said in my thread above, total cost was about $140.
Dave
Dave
[quote=Slug-O;8273847]ok picked it up yesterday. turned out 2.7 hours of labor and 54.00 of parts and shop supplies total 334.00
I can live with that...
Slug-O[/quote
Thats not bad. Glad you got er fixed. I have removed a lot of exhaust studs in my day,and most them will break off if your removing the manifolds. Not all of them all the time , but quite a few do break off. I always pre soak the studs with a penetrating fluid for as long as my patience holds out. This works pretty good. Quite a few studs will break off right where the nut is against the manifold. If your this lucky then you can soak it some more and twist it out with pliers or a stud remover if the stud is long enough. Never had to much luck with those.
Slug-O[/quote
on
Now is also the time to install a nice set of headers and replace the intermediate pipe with a better flowing section.
BTW, I keep an eye on mine and at 50k they are all still like new. I do want to replace them before they become a problem, that is when the headers, free flowing intermediate pipe mod and Flowmater 70 series muffler will be going in.
HIO Silver
50
01-17-2012 09:16 PM
Slug-O
11-28-2011 04:53 PM
79 f-150 guy
17
05-31-2011 07:51 PM
Slug-O
02-08-2011 05:45 PM
