Edge Juice w/ attitude
Hi,
I am thinking about purchasing a Edge programmer for my 07 F-250 6.0. I am having trouble deciding which one to get. Is the evolution better or the juice w/ attitude? Any input on that would be great. I have found an Edge juice w/ attitude on craigslist out of an 04 an wondered if it will fit my 07? Here s the link. EDGE JUICE WITH ATTITUDE
Thanks,
kjf-250
Thanks,
kjf-250
You'll probably not get a recommendation for either of those here.
If you really want to do any kind of performance enhancement custom tuning is the better way to go. It will cost more money, but it's much safer for your truck.
If you do a search for SCT, X3, Spartan, Innovative or custom tuning you'll find enough reading on the subject to keep you busy all weekend
on
Neither are really the best thing out there, but one is far worse then the other.
The Edge Juice module line is not good at all for the 6.0 as they do not really tune the ECM and TCM of the truck. They intercept, modify, and send out signals in order to gain the additional HP/TQ over stock. Not the safest way to go about getting gains. This is perhaps the biggest reason why Edge products have so may "eaten" trannys under it's belt and the torqshift is one of the best ones out there.
As to the Evolution, the biggest thing against it is that it isn't custom tunes. That isn't the most efficient way to go about getting the most out of your truck for your particular habits and needs. Some see really good gains, some see really bad gains and some see no gains at all, because of this one size fits all tuning that Edge products do. Also, because it isn't custom you also don't have the groundwork to expand with any other performance modifications if you should decide to go that route later on.
The big reason why the mediocre(or really just crap products) are better known is mainly due to the fact of running a good ad campaign and getting their name out there.
If it was me, I wouldn't get either one.
on
What I really can't stand to keep talking about is a/m intakes for our trucks. That's something that a/m companies don't invest more into, so the tech really doesn't change and people are still stuck with that mentality that stock, no matter what, isn't good. Most of the time that's true, but they actually got it right with the intakes. Plus, the actual negatives of an a/m intake are a little harder for people to grasp then it is with the tuners and I can understand that to a degree.
I agree, a good lengthy post on the pros and cons of tuners, I just don't know if that will happen. I've been hoping for yrs that they would put a sticky on the pros and cons of a diesel v. gas, but instead we still just get pissing matches every so often.
I have had an Edge w/Attitude for about three years. No problems, but I've read enough to make me start thinking I've been lucky.
I think I'm going to go with a SCT-X3.
I'm going to ask the folks at SCT about this on Monday, but, I'm thinking about puting my Edge in "stock" mode and continuing to use it for the gage and alert functions.
Has anyone out there done this?
on
Well, actually having gauges of any type run that risk. Mainly due to the fact that most people that run gauges more often then not run a tuner as well. Not everyone, but more often then not they do. There are very few that run just gauges.
Even though if you just run gauges and no tuner, you still should have your warranty remain intact, it boils down to wanting to fight the issue in arbitration or not. More often then not, "you'll" lose that fight for a variety of reasons.
