Help - It's cold...
Old Dec 17, 2009 | 08:03 PM
Whitebarn's Avatar
Whitebarn
Help - It's cold...
Hi all,
I need a little help. I've got a 2004 Mountaineer with the apparently all too common "blend door actuator problem." I've looked at all the great posts regarding the fix, and I'll give it a go as soon as I've got the time...
In the meanwhile, it's 16 degrees outside and I've got a long, cold ride to work. Is there a way I can manually push the blend door into the closed position so I can at least get max heat on a temporary basis without having to pull apart the center console or get behind the radio?
Any help is greatly appreciated.
Thanks alot.
