emergency oil leaking like crazy!!
alright so i started my truck this morning and bam a foot diameter oil puddle under it from over night, drove it 200km did an oil change drove it back another 200km and its almost empty its at the back around the turbo, not sure the exact location, i am at high km's on the motor and its not leaking in my valley its further towards the tansmission, any input of what could it possibly be that is leaking like constant on the top back of my motor would be greatly appreciated
thanks
dan
thanks
dan
If you have your tools handy and its your first time and thats all your going to do is replace the pedestal and turbo o-rings give yourself 2.5-3.5 hours if you can get the exhaust clamps off OK. My first time it took me a hour to get the down pipe V-clamp off.
The next time I could take the turbo off in 20 minutes.
I guess the severity here depends on how big your head is.
Pedestal o-rings is something you can easily do in your garage. The hardest part is leaning so far over the hood and then pulling the turbo out after it's disconnected. A second set of hands would be helpful. So would some type of padding so you can lay across the motor.
While pedestal o-rings sound like the most likely issue, you really need to verify the source of the leak before you go and yank everything apart. If it's those particular o-rings, there should be some sign of oil in the rear part of the valley. There are 2 o-rings between the pedestal and the block, and 2 between the pedestal and the turbo.
If necessary, poke around with a white rag on the end of a stick until you find your oil slick. I'd hate for you to pull the turbo and the leak be somewhere else.
i can take pictures if you would like to provide an email address, i got a blackberry so i can just email them off my phone tomorrow, from what it looks like to me it is leaking down from the turbo and the very back of my valley has oil not the front and my head is a medium haha but back to topic its leaking quite a bit in a short period of time and looks like its from my turbo, oil all down my new 4 inch down pipe exhaust and all over my transmission wasnt nice to do an oil change and have all that synthetic oil leak all over the ground i tell ya, expensive day
