plug in??
as for pluggin it in usually right around freezing and i have it on a timer for the usual 3 hrs before hand.
-15c is when I start to plug in if I am around a plug in,the last two winters I ran 0/40 and it started awesome this year I am running 10/30 and it has been -18c over night here so last night I figured I would plug in when I did the block heater cord shorted out and caught fire! so tonight it is getting down to -24c I borrowed a magnet heater from work put it on the oil pan hope it helps out.
You probably will have to go with what Mad van suggested ,unless you can find 0/40.
By the way your truck starts the same as mine at those temps probably smells the same too LOL
I really cant tell if my truck had bad injector O rings because that is how it has started always when it would start with bad glow plugs, and I still have the rougher idle and the non loaded in neutral hesitation at 2600 RPM...
But I ddi end up replacing them.... And now it has not failed me yet except when the fuel gelled.
'95 4x4 5-speed with 157,000-ish miles, Stancor GPR, Mobil 1 TurboDiesel 5w40, Mobil 1 ATF in the ZF5, ZeroStart wraparound warmers on both batteries and a triple-tap short extension, so both battery warmers and the block heater all plug in from one plug poking out of the bumper. Aprx. 3 hrs on the timer, aprx. 5*F yesterday morning, outdoors on a snow-covered driveway, it started up like it was July. White smoke was gone within aprx. 30 seconds.
Only bummer is, the thermostat must be stuck open; it never gets past about N on the cr@ptastic gauge, and the EBPV stays open way too long.
Fah, it's < 1200W, aprx. a hair dryer. Shoot, we run it off a generator when we go to our rustic cabin. Here's the cord to use; just the right length, and 12ga is plenty thick enough. You may also need a short (6-foot-ish) extension cord to plug the passenger-side battery warmer into, depending on the length of cord it comes with.
#28
#29
If the truck has been sitting for a few days and it is -20 C, then I plug in for 3 hours and she starts instantly. I tried it once after sitting for a week and she wasn't too thrilled. I'm guessing she would have started but I let the batteries charge overnight and plugged the block heater in for almost exactly 3 hours the next day and she started instantly the next morning.
If I drove the day before I can start right up without plugging in even if it's -20 C.
Thermometer temp, not windchill.
My only problem is the damn cabin heat. I've got a wedge in the blend door lever until it gets warm enough outside to work on it !
ol-blu
06-12-2020 11:17 PM
Chevy_Eater
41
07-25-2015 09:14 PM
52 Merc
31
01-18-2012 09:03 PM
