Broken OD Switch (TCS) on Shift Lever - Need Wiring Diagram
the Transmission Control Switch (TCS), aka OD switch, has once again busted off my shift lever. I've successfully glued this back together 3x before but this time the wires got broken off flush so that I can't tell where they go anymore. Does anybody have a wiring diagram for this?
what broke off is the last 2" or so of the stalk. There are 3 pins into which the actual switch plugs into, and they're labeled 1, 2, & 3. The connector at the other end (at steering column) is wired:
A = green
B = violet / orange
C = tan / lt blue
so which ones are 1, 2, 3 ??
A = green
B = violet / orange
C = tan / lt blue
fordsforever2015
11-12-2021 11:35 PM
oldguard60
04-08-2014 06:07 AM
