i got a 88 f250 i put a new 351 create engine in it. everthing is hooked up, its got fule ,spark, compersion, and the timing is right. it will crank over but not fire i was wondering if i had to reset the computer or wat anything helps guys thanks
How did you set the distributor? You need to start with #1 cyl at TDC on the compression stroke and then insert the dizzy so the rotor points to the #1 post on the cap. But don't tighten down the distributor, leave it loose enough to turn and if the motor doesn't fire when cranked rotate it clockwise a little and try again until it does. If you find the distributor needs to be really cranked around then it's misaligned a tooth, remove and insert it counter clockwise 1 tooth.
