Over-drive questions in re-guards to towing
Old 12-04-2009, 07:03 PM
thePUNISHER
thePUNISHER is offline
thePUNISHER is starting off with a positive reputation.
Originally Posted by 6CylBill View Post
Well this is somewhat amusing. I was leary about introducing a Dodge into the family. It has low miles. It felt very solid.
However, it already has a problem.
It does not blow any heat.
It is Winter. It's cold.
Looks like we might be taking the Ford afteral.
lol...to be hones id rather risk the e4od in O/D than trust that the dakota automatic would hold up....lol.....
Old 12-04-2009, 07:24 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
Yeah... No doubt. And mine has 217K miles. The Dodge has less than 50K.
Old 12-04-2009, 07:38 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
I use OD when towing ONLY on flat ground and after reaching highway speeds........Any uphill grades or downgrade, and its back to 3rd............not worth risking a trans, even with a big trans cooler on a E4OD.
Old 12-04-2009, 07:46 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Thanks a lot Dave
Old 12-04-2009, 07:55 PM
94MustangGT's Avatar
94MustangGT
94MustangGT is offline
94MustangGT is starting off with a positive reputation.
^Old93, my E4OD truck(with the towing/cooling packages) doesn't tow, but hauls 1000-2000 pounds of payload semi-regularly. Otherwise it racks up its miles empty. Does it need a larger cooler?
Old 12-04-2009, 09:00 PM
Old93junk's Avatar
Old93junk
Probably fine the way it is, but it will never hurt to buy some insurance with a big aftermarket trans cooler...................Who knows what you might want to tow home in the future!
Old 12-04-2009, 09:16 PM
94MustangGT
^ Cool, are you running the stock cooler or an aftermarket one?
Old 12-04-2009, 09:24 PM
Old93junk's Avatar
Old93junk
I replaced the stock HD "stacked plate" type for a 18"x18" Hayden cooler...............I have never had a hot trans since, even after towing a 12,000lbs 26ft cabin cruiser over to the coast for a friend.(hopefully that boat will never come back from the coast)
Old 12-04-2009, 09:32 PM
94MustangGT
Alright, thanks man. I'll check that out.
Old 12-04-2009, 09:40 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Check out the blend doors on that dodge....
Wilmax
04-21-2013 08:44 PM
Voodoo66
03-20-2011 12:05 AM
aharrell
03-27-2004 08:39 PM
bigolbob
12-11-2003 01:31 PM
E-350cargo
08-18-2003 08:48 PM
Quick Reply: Over-drive questions in re-guards to towing
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
