What engine oil do you guys use
Hi Guys
I've always used 15/40 engine oil in my engine. A hot shot Ford mechanic (which I am not) once told me that the oil to use was 10/30 'cause it was better for the injectors. But I was thinkin' what about the rest of the engine???
So what do you guys use and why?
Motorcraft makes a Diesel Rated 10/30.
I am currently running Schaeffers 7000 15W40. I have also ran Schaeffers 9000 5W40 Full Synthetic. I will be switching back to the full synthetic on my next oil change. My truck loves both oils, but winter is here so im going to go full synthetic and stick with it. it costs a little more, but my truck runs better with it
Yep -- there is a 10W-30 (Oil Rotella T 10w30 Gal America's Farm & Home Store), which is a decent alternative to syn, I guess. I think 5W-40 is better, because it's still like a 40-weight oil when fully warmed up. Normally, a change is due when a 40-weight breaks down to 30. I would think 10w-30 might be a bit too thin after a normal interval. Just my not-so humble opinion...
Esso xd3 10w30 is a diesel rated oil and i use in all my customers cat equipment oil changes in winter also some of the construction companies that i have work for also used this.
from my understanding this is one of Esso better oils
Great OA reports from using this oil, and it's usually only a little over $9/gallon when I pick it up on sale.
