upgrading my f150
Old 12-03-2009, 11:36 PM
1868pike1978
1868pike1978 is offline
1868pike1978 is starting off with a positive reputation.
upgrading my f150
i have an 88 fi50 4x4 with a 5.0 efi and a 4 speed tranny. im wanting a bigger or more powerful engine and a 5 speed tranny. not sure what will fit. hope yall can help
Old 12-04-2009, 12:08 AM
97FRD1TN's Avatar
97FRD1TN
97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
Well define "bigger" a big 302 or a big block?The biggest you can find stock to bolt on to your existing tranny is a 351 and for all the trouble you will gain 20 horse or so and 50 ft lbs of torque.As far as I know any 5 speed from 1987 to 1996 should work.I guess be more specific on the motor so we can help you better.But I guess start with the exhaust,headers,free flowing muffler,gears help a lot,cam,intake,heads etc.
Old 12-04-2009, 01:01 PM
1868pike1978
well im not sure which way i want to go. i have a 351m but i heard that wouldnt work, i have tought obout getting a 302 HO because i was told they can be fixed up more.
and on the tranny will i have to get diferent drive shaft length if i upgrade to a 5 speed
My reason for wanting this is because im am going to be using it to pull a gooseneck
with my 4 wheelers or a truck on it.
Old 12-04-2009, 02:14 PM
1OldFordMan's Avatar
1OldFordMan
1OldFordMan is offline
1OldFordMan has a great reputation on FTE.1OldFordMan has a great reputation on FTE.1OldFordMan has a great reputation on FTE.1OldFordMan has a great reputation on FTE.
351 will fit. You will have to change some stuff. Know exhaust, not sure what else. Bellhousing is the same 300 6cyl, 302, & 351. If you've already got a good 351, I wouldn't spend money for another engine. Do know the computer may be different depending on years. Something about the firing order. If Conanski or somebody else sees this, they can answer better than me. I'm just going with what I remember reading here on the computer & firing order.
Old 12-04-2009, 02:23 PM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
351M is a different animal from the Windsor series 302/351. 351M is part of the 335 series engines. Same bellhousing pattern as the 460.
Old 12-04-2009, 02:50 PM
1OldFordMan
My apologies. Thought the M was the Windsor. Know the Clevelands were C for Cleveland.
Old 12-04-2009, 03:52 PM
FORD RANGER's Avatar
FORD RANGER
FORD RANGER is offline
FORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud ofFORD RANGER has much to be proud of
the windser will fit in a 302 spot. the 351m and the 400 are big blocks.
the 351 w will fit and bolt up to your tranny.
Old 12-04-2009, 04:15 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
I have tought obout getting a 302 HO because i was told they can be fixed up more. .
You can't do any more to a 5.0HO than you can do to a 5.0 truck motor, it's essentially the same motor with a different cam and intake so it would be a lateral move at best. And besideds that it's still only 302 cubic inches and you need lots more TQ than it can deliver for serious hauling. A 351w is the best candidate, throw some upgrades on it and add 4.10 gearing to your axles and it'll haul pretty good.
Old 12-04-2009, 08:22 PM
FORD RANGER
its a big small block.. longer stroke and small block heads. the intake is an inch bigger
but the heads are the same..
f1501987
24
10-05-2011 07:23 AM
saber96
04-07-2010 08:08 AM
creedua
New Member Introductions
03-04-2008 05:27 PM
AceRedRock
03-24-2004 06:42 PM
catpeterbilt379
02-07-2002 10:51 PM
Quick Reply: upgrading my f150
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
