Help with check engine code.
Old Dec 3, 2009 | 09:11 PM
BlackFX4Screw's Avatar
BlackFX4Screw
Just got my plugs changed. Truck is running great. My check engine light came on. Went to Autozone to check the code.
Troubleshooting P2106
OEM Brand: Ford
Definition: Throttle actuator control system- Forced limited power
Explanation: Throttle actuator control system is in FMEM mode of
forced limited power
Probable cause:
Open or short circuit condition
TACM motor stuck open or closed
Other system hard fault/failure
Any help about what this means?
Old Dec 3, 2009 | 09:41 PM
bridge's Avatar
bridge
Sick 'n Tired
According to the service manual this is an informational DTC that is accompanied by other DTC that explain why your truck is going into failure mode. Where there any other codes? If not, I'd reset the PCM by unhooking the battery for 30min and see if comes back.
Old Dec 4, 2009 | 05:09 AM
wtourvil's Avatar
wtourvil
If you disconnected power to change plugs, this erroneous code should just be erased.
Old Dec 4, 2009 | 05:58 AM
shorebird's Avatar
shorebird
Have the person who read the codes reset/clear them. Drive the truck and see if they return.
Old Dec 4, 2009 | 06:14 AM
BlackFX4Screw
That was the only code. I disconnected the battery this morning. Will see if the CEL comes back on the way to work.
Thanks for the replys
Dec 28, 2016 05:17 PM
sugarcane
2004 - 2008 F150
Oct 18, 2016 06:56 PM
jfish1288
Dec 21, 2015 09:32 AM
Biker1966
2004 - 2008 F150
Dec 4, 2015 02:20 AM
Mikey_23_ny1
Feb 27, 2015 05:01 PM
