redundant 302 fuel mileage gripes...
Old 12-04-2009, 04:12 PM
BCHauler's Avatar
BCHauler
BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
Dual tanks? Check to see if you have any cross filling going on. More than a few people here have found that to be the cause of their bad fuel mileage.
Old 12-04-2009, 08:33 PM
Bayer-Z28's Avatar
Bayer-Z28
Bayer-Z28 is offline
Bayer-Z28 is starting off with a positive reputation.
^ Yeah I've got dual tanks.. the other is dry with a pump that went bad two months ago.. I pumped the fuel out and into the rear, working, tank..
Old 12-04-2009, 08:45 PM
94MustangGT's Avatar
94MustangGT
94MustangGT is offline
94MustangGT is starting off with a positive reputation.
Make sure your speedo/odometer are correct, and that your method of calucaltion is correct.
BTW, those K&N's need to be cleaned every 10-15K miles, just as you would replace a paper filter. Some people will say they can go 50K miles inbetween cleaning which is rediculous. Ditch the Fram oil filter too, try a Motorcraft or Puralator.
You metioned cleaning the MAF senor, might as well clean out the trottle body while your at it.
Old 12-04-2009, 10:24 PM
Bayer-Z28's Avatar
Bayer-Z28
^ That sounds good.. I've just read somewhere that someone was complaining that the Fram filters starve the oil delivery.. I'll throw a motorcraft on there next time.. I'll TRY and change it this weekend.
I usually check the TB every oil change, but it's been a while and I'm slackin a bit.. GOnna be truck maintenance tmrw.. and I gotta look for sled parts..
Old 12-04-2009, 10:56 PM
94MustangGT
^ Cool. Someone had mentioned checking the codes. That's worth doing.
Don't forget to grease any fitting while your under it changing oil too. Good luck.
Old 12-05-2009, 07:16 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Since its been mentioned, just ditch the KN for a good quality replacement filter.
Old 12-05-2009, 07:42 AM
Argo's Avatar
Argo
Argo is offline
Argo is gaining momentum as a positive member of FTE.
I have a 1996 F-150 with the 300 six in it, and I got greedy once. At 120,000 miles, I swapped in a 302. I had to have a V8. They run great in cars, so I thought I'd be happy with it in my truck. Unfortunately, I found that is drank very heavily, and wasn't happy with heavy loads. I swapped back to the six after about 30,000 miles. My logs indicate that I got 14-15 mpgs on the highway, and 9-11 around town. My 300 averages 14 in town and 21 on the highway. That is with no overdrive and 3.73 gears. I just have to do 55 MPH. I love the 302, but not for trucks. I am not trying to insult anyone, this is just my observation. Nobody I know with a 302 in a truck does well on fuel mileage. On the plus side, they are durable, easy to care for, and will last about forever if you treat them right.
Old 12-05-2009, 08:11 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
My truck has 3.08 rears in the rear end, and a 5 speed with the 302, and empty on the highway gets around the 21-22 mark also. I have a few (4) of these years of trucks and the manual tranny truck does get a few mpg better then the autos.
I think your doing right on spot with the truck you have, and the mileage your getting.
4spots
1997-2006 Expedition & Navigator
29
11-08-2012 08:07 PM
BirdmanStyll
2004 - 2008 F150
07-30-2009 08:50 PM
caleb
1999 to 2016 Super Duty
05-01-2007 06:56 PM
jor1369
27
04-01-2005 06:53 PM
5011
10-19-2001 10:55 PM
Quick Reply: redundant 302 fuel mileage gripes...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
