Can I tow?
get air helper springs for the rear of your truck so you won't lose the softer ride. but defiantly boost your brake system like everyone is saying. and if you haven't already you mite wanna look into like intake and exhaust for that extra needed power to pull over the grades, possibly a trans temp gauge to be on the safe side
Has anyone ever tried the active suspension system? http://www.activesuspension.com/
In theory, it sounds good because allow for a nice ride and still give more stability and more load handling .
Good points. I'm not sure about the gearing, only had the truck for 1 1/2 years and only 5000 miles, and I never had a need to know. One thing I know is I need to give more gas when starting out, than I did with my 3/4 ton V8. I had not thought about the frame... guess the newer ones are boxed. Even though it's built Ford tough, may not be good enough for this job!
I would recommend checking the gearing as well.
It depends on how far and often you will tow the trailer. Have you actually weighed the trailer to find out the true weight?
I wouldn't even think twice about hauling that much with my F150. Hell, it has pulled around 8K a few times since I've had it.
My trans (M5OD) went early this summer, with 155K on it. Not bad considering the truck had towed a '29 camper before I got it. I put in a used trans with 60K
My 300 would laugh and walk away with a load as light as what you're looking at.
This is just my 2 cents, these trucks were built to work.
It will tow it fine, and you dont NEED a weight distributing hitch, or air bags, but they both do add some security and stability.
And as for the truck being able to handle that heavy of a trailer, it shouldn't have a problem. These trucks are vary strong, including the 300 and the Mazda 5speed(keep it full of fluid). My truck has 3.08 rear end and it pulled loads 6,000+ #'s and huge wind loads without a problem. I could hold 70 all day long. But stopping is often overlooked. Make sure you have good trailer brakes.
And most people will tell you to get a 3/4 ton, mainly because bigger is better. And i agree, but i have a 1/2 ton and use it as long as i feel that it is safe. And so far i feel comfortable up to about 8k depending on the load.
I'll look up what your truck is rated to tow, just for kicks and grins!
Jeez mater, I just ran out in 32F in my underpants just to grab this book for you! You owe me a pizza or something 'cause that sucked! haha.
Your truck is rated to tow 7,500 lbs. Pretty impressive!
#28
it must be safe for me to feel comfortable. I'v had my fair share of close calls and I must be sure that my truck can handle the load before ill pull it with my truck. If i need more truck i can always get it. I have access to all kinds of tow vehicles if i need them.
I have the original owners manual from my 93' and i believe that the recommended tow rating for a 93' F150 with a 351 with 4.10 is 7,000+ lbs. Remember, that is the same exact truck as mine, just a different engine and trans. The brakes, frame and axles are all the same.
How would my truck be more dangerous when the most concerning issue is braking and control?
#29
#30
