motor swap done carb issues
Old 12-30-2009, 12:02 AM
blisstruck's Avatar
blisstruck
blisstruck is offline
Question motor swap done carb issues
I just bought a 65 f100 that smoked real bad out of the driver side of the 352(tail pipe) The truck came with a FE with 73 casting numbers on the heads. I ran some seafome through the first, just smoked more. I decided to swap out the motors to see if the 73 was better. 16 hours of work later NO Smoke! I used the holly carb off of the old motor and the Idle screws don't change anything, the truck will not idle without the choke on a bit. Dose this sound as if something is clogged, broken or miss-adjusted? I also have a motorcraft carb that came with the 73 FE is one better than the other? Any help would be appreciated. Thanks 2V carbs <!-- / message --> <!-- sig --> __________________
Old 12-30-2009, 01:58 PM
bertha66's Avatar
bertha66
bertha66 is offline
Having to run with the choke closed a bit sounds like a vacumn leak. I would switch out the carb just to see how it runs.
Old 12-31-2009, 01:57 AM
46yblock's Avatar
46yblock
46yblock is offline
Just put a new kit in it after good cleanup, and sell me your 2100 . But check for vacuum leak first.
Mike
Old 12-31-2009, 04:20 PM
customcab66's Avatar
customcab66
customcab66 is offline
my 66 did that to me after the carb sat for about a month turned out that a but had plugged up the carb in the air fuel mixture body behind the freont bowl on my holley to an air hose to it and that was that
Old 01-01-2010, 04:41 PM
blisstruck's Avatar
blisstruck
Thanks for the input. I haven't had time to tinker with it yet but will keep you posted. Ya Mike if you need one I am needing to keep this on a skinny budget. when I get the holley sorted out I'll let you Know.
Old 01-04-2010, 11:55 AM
bertha66's Avatar
bertha66
bertha66 is offline
I think you ment BUG that had plugged that carb, not but. LOL
Where ya at?
Old 01-05-2010, 11:11 AM
blisstruck's Avatar
blisstruck
Ya I thought it might be dangerous flipping buts into the carb. I had some time to tinker a bit with the carb and sprayed carb cleaner at the base of the carb the idle did pick up slightly I guess that I need to get new gaskets and re install it. where did you blow air into the carb? did you remove the adjustment screws? not real sure that the pickup wasn't from fumes going into th air cleaner. I may chuck the big block and go with a 6 or a 302 I have a 302 anyone know of a 6 I could trade my 360 for ?
Old 01-05-2010, 09:45 PM
customcab66
sorry that was a long day besides not all of can be perfect all the timme right lol
Old 01-05-2010, 11:12 PM
46yblock's Avatar
46yblock
46yblock is offline
I will just throw this out as an option. A retired mechanic friend rebuilds 2V carbs for $40. You supply the kit. Problem solved. Shipping within state shouldnt be much. If you want you can ship it to me, I will take it and retrieve it from him, reship. He only lives 5 miles away and I'm over there fairly often.
I have had Bill rebuild at least 9 2100 Autolites for me, everyone worked perfect. Finally decided to stay and watch from beginning to end, and now am doing my own 2100s. 2300s are basically the same animal. He is a phenom in my book.
Today I dropped by to see if by chance he had an early Ford vacuum advance left over from his Dyno days.
Yep, and as with everything else he does or has, a lot less expensive than other sources.
Mike
Old 01-06-2010, 01:28 AM
blisstruck's Avatar
blisstruck
carb man
I will keep that in mind. where in Oregon is are you I am in Salem but often make trips to Portland.
Old 01-06-2010, 02:06 AM
46yblock's Avatar
46yblock
46yblock is offline
Basically Grants Pass. Actually 15 or so miles so. of GP, in Williams. Send email or PM if further interested.
Old 01-06-2010, 10:37 AM
blisstruck's Avatar
blisstruck
Oh I don't get that far south very often. I may box it up. but not quite ready to let go of it yet.
7283-F250
06-11-2013 05:51 PM
jmcnair40
24
12-25-2011 01:56 AM
shiftonthefly1
08-09-2010 11:11 PM
pittmick
01-27-2010 02:06 AM
elwood
08-02-2003 03:31 AM
Quick Reply: motor swap done carb issues
