I can now officially join your ranks
According to that number, it is:
F1 = 1/2 ton Pick-up
R = 239 Flathead V8
2 = 1952
CS = Assembled in Chester Illinois
11837 = it was the 1837th 1952 truck built there.
So it should have a flat sided 6 1/2 foot "Pick-up" Box bed.
The front fenders have been replaced on the truck as they have the larger openings for an F2+. The upper valance (where the letters "F O R D" should be on a 52) was probably replaced at the same time with that off a 1951 truck (no letters).
You might ask the owner why the front sheet metal was replaced (it may have been wrecked)
Front fenders will rot in the seam between the upper and lower portions of the fender (you can see that seam), and at the rear where it bolts onto th erunning board. But the upper and pretty much the lower valances were not a rust problem and seldom required replacement unless wrecked. He might have bought the entire thing as an assembly off a 51 F2 and swapped it out as an assembly, just to fix the typical corrosion problem in the fenders - but they (fenders and upper valance) are not the ones built on the truck.
Looks pretty nice though and should make a fun project!
R = 239 Flathead V8
2 = 1952
Hillbilly Rockstar
25
02-27-2012 02:57 PM
Longland
10-16-2011 05:33 PM
boston8273
11-27-2010 10:26 PM
l67cooled
11-30-2009 12:59 AM
