Looking at the F-650 dash panel
#46
#47
I will have them on the website shortly, but here is a pic for you. They will come plug and play, painted and ready to go.
Attachment 19779
Attachment 19779
#51
#52
#54
There's a write-up in the 7.3L forum. I'll go look for it.
Riffraff Diesel: Riffraff Custom Auto Dash Kit
Stewart
#55
I may go back later and get some with graphics to go with it like these:
OTRATTW
RiffRaff put in the two tunnels for the gauges, I added those (Oil Temp and Trans Temp, Glowshift Elite 10 series).
You have to send RiffRaff your trash hook and cup holder so they can color match the paint exactly.
Install was simple:
1) Remove the stereo
2) Remove the two small screws long the top edge of the stereo opening
3) Tilt the wheel down, hit the e-brake, put the truck in "1"
4) Gently pull the dash surround back - the entire thing from the stereo and vents on the right to the light switch on the left is all held in place with clips.
5) Disconnect the switches (lights, 4x4 if equipped, parking sensor cutoff if equipped, rear defroster, power port) and set the dash surround aside
6) Two screws at the top of the old panel and two at the bottom (may be one or two more around the trash hook if memory serves) and remove
7) Put the new 650 dash panel in (after hooking up your switches and installing your gauges)
8) Do steps 1-5 in reverse
I bought the switch connector option (where they provide you a plug for each switch) so I was able to make the harness before I ever started. Doing it that way I was able to make the harness on one day, then when it came time to install it only took about an hour.
#56
Ok, I was wrong. There are quite a few "picture threads" where guys have posted they installed the dash, but no actual write-up threads.
I double checked with Clay and he confirmed it. He did say it's a straight-forward install though. Maybe he'll chime in on the thread.
Stewart
Stewart
#58
You'll love it. Aside from the V/Modded B work I did, this is my favorite mod. I love how it is an OEM solution. I've lost track of how many people ask me about it when we put it on display.
#60
We are machining another 30 dashes and should be ready to go and caught up in about 2 weeks.
