Stock manifold to headers 1994 F250 351w
Old 11-27-2009, 07:14 PM
StrongerThanaCHEVY13
StrongerThanaCHEVY13 is offline
StrongerThanaCHEVY13 is starting off with a positive reputation.
Exclamation Stock manifold to headers 1994 F250 351w
Hey everybody. I'm looking at buying a 1994 F250 reg cab LB with the orginal 351w and a 5 spd manual tranny. The stock exhaust manifolds were leaking says the guy, so he replaced them with headers last month. The headers are in good shape, but I have a question. The guy who's selling it didn't reconnect the exhaust. I can see the headers, then I lose sight of them behind the suspension. Then behind the front wheels there sticks two pieces of 3 or 3 1/2 inch flexi-pipe (one on each side) running down towards the exhaust pipes. The exhaust is two pipes, 3 inch i think, side by side. He says that I would have to cut the exhaust about 3 inches shorter, and connect the flex-pipe, and put some clamps on it. Whats the verdict, crap or truth?
http://images.craigslist.org/3k73oa3...9fc9a41226.jpg
Old 11-27-2009, 07:15 PM
I've seen this truck in person, it does run and drive, and it is loud. the link to the ad is
1994F250 PLOW TRADES WELCOME
Old 11-27-2009, 07:38 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
They look like shorty headers. They will bolt up to thee stock y-pipe. Unless he did away w the y-pipe
Old 11-27-2009, 08:18 PM
Why would it have a Y pipe? It runs two pipes from the headers back to the cat and muffler...? Heres a diagram I tried to draw, see if it helps.... Thanks
[IMG]<a href="http://s774.photobucket.com/albums/yy21/x3daysaway13/?action=view&current=exhaustdiagram.jpg" target="_blank"><img src="http://i774.photobucket.com/albums/yy21/x3daysaway13/exhaustdiagram.jpg" border="0" alt="1994 ford f250 351w exhaust headers diagram"></a>[/IMG]
Old 11-27-2009, 08:26 PM
Diesel_Brad
[QUOTE=StrongerThanaCHEVY13;8178523]Why would it have a Y pipe? It runs two pipes from the headers back to the cat and muffler...? Heres a diagram I tried to draw, see if it helps.... Thanks
Because that is the whole point of running shorty headers, to keep the y-pipe. If you didnt want to keep the y-pipe and run true duals then long tube headers would be the headers of choice
But hey, you looked at the truck. If you cant figure it out by looking at it then there is no way in hell you can explain it to us to help you out
Old 11-27-2009, 08:31 PM
Sorry man. I didn't mean to sound like, condescending or something. I just don't understand. Where would the y pipe be? Y pipes are two into one, right? Or am I totally off base? I have no clue. Is it up closer to the headers than where I am looking?
Old 11-27-2009, 08:36 PM
Diesel_Brad
Yes. the y-pipe comes off the manifolds(or shorty headers) and into one pipe, then the cat, then the muffler then the pipe continues out the back of the truck.
How old are you?
Old 11-27-2009, 08:40 PM
I am 16, looking at buying my first truck for plowing. My only auto work experience is from working on my 02 Saab 9-5, and even then, all i've worked on is the cooling system.
As for the y pipe, are you saying it goes, from fron to back,
engine, headers, y pipe, single exhaust pipe, cat, muffler, tail pipe?
what happens if there are two exhaust pipes?
Old 11-28-2009, 12:08 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Sounds like the truck is missing the Y pipe, you could fabricate one but Bassani makes one with and without a cat depending upon your needs, a few guys here have installed and like them.
larry_fopps
31
11-09-2017 12:50 PM
FullMetalDiesel
6.7L Power Stroke Diesel
10-14-2016 09:16 PM
FullMetalDiesel
09-18-2016 08:46 PM
towmaster
Ford Truck Parts for Sale
01-17-2016 01:29 PM
puffc
Exhaust Systems
01-11-2001 12:00 AM
Quick Reply: Stock manifold to headers 1994 F250 351w
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
