Lower Rat hose spring?
Old 11-27-2009, 09:21 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
When did they start NOT putting a spring in the lower radiator Hose? I just picke up a set of hoses for my 1989 F250 /W 351W and there is no spring in the hose. Now like 3 days later I had to pick up a set for my 2000 GMC Jimmy and there's no spring in its lower hose? Is it ok to run without the spring? or do I need to try to pull the old one out? Responce from the parts chick was not sure why some come with a spring and some with out. I need to do the jimmy today as we almost over heated yesterday but the truck can wait as its still missing about 75% of its body.
Old 11-27-2009, 09:27 AM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Some have the spring molded into the rubber.
The last one I put on I did take the old spring out and put it in the new one.
Some think it does not need one if you have a good 14 psi radiator cap to keep the hose inflated.
Old 11-27-2009, 10:49 AM
fishforlife2007's Avatar
fishforlife2007
fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
u dont need it if your new hose doesnt have it..in this case that is..
Old 11-27-2009, 01:42 PM
RustyGreen's Avatar
RustyGreen
RustyGreen is offline
RustyGreen is starting off with a positive reputation.
I was told that it was because of the difference in the rubber that they use on newer hoses. That it is stiffer so it doesn't need it.
Sounded good enough for me so I went with it
Old 11-27-2009, 02:02 PM
Ohio Ford Farm
Well the original one on the jimmy did not have a spring inside it and that made it 10 years and 160,000+ so I guess the new one should be fine. Just kind of got me off guard as it has been make sure the spring is in the lower hose all them years and now poof its gone! lol Thanks for the responses.
Old 11-27-2009, 05:55 PM
wolfsmurf's Avatar
wolfsmurf
wolfsmurf is offline
wolfsmurf is starting off with a positive reputation.
ive been to several meetings since they started NOT putting in the springs and have been told by hose factory reps that like the above guy posted it is the quality hoses made today dont need the spring to hold its shape. i personally think it is because they wanted to get cheaper......
Old 11-27-2009, 06:51 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
zxwut? has a good reputation on FTE.zxwut? has a good reputation on FTE.zxwut? has a good reputation on FTE.
I like the lack of the spring. Less stuff to get lost in my coolant system and clog something.
Old 11-27-2009, 08:33 PM
ArdWrknTrk
ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
...'Till you suck it flat and cook your engine.
Old 11-28-2009, 01:11 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
It won't happen with a hose without a spring. Springs work great until they fail and suck flat
Old 11-28-2009, 11:57 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Thats right, when we were carrying goodyear hoses at my store, they didn't have springs and the rubber was really firm. Since we got bought out and started carrying Gates and Master Pro hoses, you feel a real difference in the firmness of the hose. They need springs in them to prevent a collapse. At least it seems the springs they use these days dont corrode and fall apart anymore.
keisha9
03-18-2016 09:26 PM
carl2591
06-14-2015 06:03 AM
hombre292
03-29-2015 07:10 PM
sowaxeman
10-29-2014 07:54 AM
The Masked Rider
13
05-13-2014 05:34 PM
Quick Reply: Lower Rat hose spring?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
