2008 7 pin color code
There should be a legend on the cap of the light socket. You might consider buying a trailer light plug and wiring to it.
Use heat shrink butt connectors or heat shrink tube in either case.
Back up lights are the center pin.
marker lights are the 11 o'clock pin.
If you are installing a high draw light, install a relay.
AndeyHall
02-20-2018 08:03 PM
V10Crew
10-28-2010 03:13 PM
