Has anyone out there ever try using resistors to bring voltages down on both EOT and ECT ??????????
all that does is make it a false reading! If you need to do that you need a cooler and/or head gaskets and possible an EGR cooler. The spread isn't due to faulty wiring. it could be, but usually it is what is listed.
I have flushed cooling system, installed ARP head bolts with new Ford head gaskets, installed IRP external oil cooler, IRP coolant filter, 4 inch turbo back stainless steel exhaust system, new thermostat and both ECT & EOT sensors & EGR delete.
Where do I go from here ??????
Read the stickies at the top and then if you have a question start a new thread.
I didn't write them down but there was 34 degrees difference between the two.
I also checked the FICM and all voltages were in specs.
Well they are going to be important to figure out the problem.
For instance, if the ECT is 160° when it's fully warmed up then you probably need an new thermostat. If the ECT is up over 210° unloaded then a water pump would be more likely.
I will recheck the temperature and give you the temperature and the voltages.
Could still be in bypass causing the hotter oil readings.
Josh
The IPR unit uses it's own filter housing, the EOT is relocated to the oil cooler Input hose. I would think that being out on top of the oil cooler verses being on top of the block it would be cooler.
