What do I have to change
Old 11-24-2009, 05:36 AM
fordtruck4x43025.0
fordtruck4x43025.0 is offline
fordtruck4x43025.0 is starting off with a positive reputation.
If I put a cam in my 95 f150 302 EFI. What all will i have to change? Its a x303 542 lift 286.
Old 11-24-2009, 07:23 AM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Are you replacing it with a stock cam?
Old 11-24-2009, 08:52 AM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
This is a lousy truck cam... the motor will be a gutless wonder below 3000rpm. If you do install this you need mass air, upgraded valve springs and retainers, a high stall converter unless it's a manual truck, and more likely that not the pistons will have to be clearanced to prevent them from hitting the valves. It's all right there in the footnotes on the Ford cam page.
NOTES:
<SUP>(1)</SUP> On EFI engines, performance camshafts work only with mass air induction systems. .
<SUP>(4)</SUP> May require piston modification for piston-to-valve clearance. Valve clearance should be checked.
<SUP>(7)</SUP> Hi-Stall torque converter recommended for automatic trans.
Old 11-25-2009, 04:07 AM
fordtruck4x43025.0
what would be
What would be the best cam to go with?
Old 11-25-2009, 04:52 AM
Lazy K
Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
If it was me, I would go to summitracing.com and look at their cams that are compatible with SD (non MAF) engines.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
