F250 4x4 Front Axle Codes - Page 2 - Ford Truck Enthusiasts Forums
Old 11-24-2009, 03:48 PM
1994 F250: 351, C6
1994 F250: 351, C6 is offline
1994 F250: 351, C6 is gaining momentum as a positive member of FTE.
Look on the bottom of the pumpkin. The Dana 50s have "50" stamped on them. My '94 F250 regular cab, with the 351, and 8600 lb GVW has a Dana 50.
Old 11-24-2009, 10:36 PM
Ford6.02005's Avatar
Ford6.02005
Ford6.02005 is offline
Ford6.02005 is starting off with a positive reputation.
Originally Posted by mrfix71 View Post
I have been through many websites trying to find out what front axle my truck has. The door stickers are gone. The axle tag is there but numbers do not match what I can find stamped around the bolts.
On the axle, I found the numbers 734 and then (upside down) I found the following: P280 8 2
below that: 41582 B
The tag itself: 4 09 VF81A UC
below that: (triagle) 61031(4 or 1) 28 (?)
Anyone know of a source for the IFS codes?
Your Bill of Material # does not match any of the possibilities... look at the drivers side axle housing around the u-bolt area for a 6 digit number starting with a 6 then a dash then 1 or 2 additional numbers. The 4.09 ratio tells me you have a D44 IFS since D50 IFS gearsets are 4.10 ratio!
Old 11-26-2009, 11:17 AM
tjc transport's Avatar
tjc transport
tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
in the pictures Andy posted, the truck with the dana 44 ifs has a full floater 10.25 sterling rearend.
it is an 89 F250 HD with a 351W, E4OD trans, and currently has 61,526 miles on it.
Old 11-26-2009, 02:23 PM
andym's Avatar
andym
andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Thanks for those pics Tom, I'm still using them and putting them to good use!
Old 11-26-2009, 03:08 PM
tjc transport
i ain't rite
i'm glad you have them stored for easy access.
i have to go through 500+ pics in my photobucket account to find them
Old 11-28-2009, 08:23 PM
mrfix71
mrfix71 is offline
mrfix71 is starting off with a positive reputation.
Not to beat a dead horse or anything, but the more I dig into this truck, the more confused I get. The rear axle, a 10.25" according to all reference material, has the following tag, which is easily read:
2 V111C
4L10 10 2 8L08
I understand this to mean the rear axle has 4.10 gears with a locker, 10.25" ring gear, and made on 12/8/88.
With the rear axle identified, is it reasonable to have 4.10 ratio in the back and what the front tag appears to be 4.09 in the front? Is this close enough not to be of any concern?
I will look for more markings on the front axle tomorrow but as of now it seems I have a straight D44 and not the HD or D50.
Old 11-28-2009, 08:28 PM
tjc transport
i ain't rite
4.10 rear and 4.09 front is standard.
the front gears are usually 1 or 2 points off from the rear gears to aid in traction.
if you have a straight axle in it and it is a F250, it was swapped in there, because the F250 came with an IFS front suspension. the F350 came with a dana 60 straight axle.
Old 02-07-2010, 02:18 PM
swervin
swervin is offline
swervin is starting off with a positive reputation.
Does a Dana 50 bolt up to a dana 44 ifs arm? can this be done and has anyone done it?
Old 02-08-2010, 01:35 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
^^^ The answer to that all depends on the application. If your F250 had the Dana 44TTB HD, yes, the Dana 50ttb will bolt right to its drop arms. I did it in my F250.
BUT, if your talking about an F150, no, it will not work. The arms are shaped different and in different spots.
Old 02-28-2013, 11:01 AM
87straightsix
87straightsix is offline
87straightsix is starting off with a positive reputation.
Lightbulb 1987 f250 Sterling 10.25" & D44 IFS
I am currently redoing ball joints on my truck. I needed to research which front end I had so I could buy the right spindle nut wrench. After reading the thread, I am one of the lucky owners of a Sterling 10.25 semi-floater and D44 IFS. I was a bit surprised about the D44 with it being a 3/4 ton. I though D44s were mostly on 1/2 tons and broncos. But I learned something new as well. But with it being an 87, it is a lighter duty 3/4 ton. I'm ok with it now because the 97 4-door SRW is coming in a year or two!
Old 04-02-2016, 10:26 AM
johnjg
johnjg is offline
johnjg is starting off with a positive reputation.
MY CODE IS 11 ON A 2000 F 250 DOOR TAG,CAN'T FIND IT THE RATIO
Old 04-02-2016, 12:13 PM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
You will probably have better luck in the correct forum: Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
FWIW....My Ford Service Manual does not list Axle Code 11 for your year truck. Are you sure you are reading yours correctly?
flowney
12-28-2017 04:54 PM
Fat Gav
10-03-2017 06:30 PM
OFLM
12-13-2016 02:58 PM
64M100builder
08-07-2016 12:02 PM
jpmillbauer
05-24-2016 08:46 AM
Quick Reply: F250 4x4 Front Axle Codes
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
